[gdal-dev] Re: GDAL JAVA problem
sagar_sahay
sagar at spiffymap.net
Wed Oct 13 05:01:23 EDT 2010
Even,
I am actually trying to run the ogr2ogr.java from the link which you have
specified. In that if I don't load all the .so files individually it gives
me an exception at .AllRegister() method and the execution stops, but when I
load them individually it catches the exception and displays the exception
message as displayed in my previous post without stopping the execution. I
have manually built and referenced the gdal jar file in the netbeans
project. The exception message is still coming though.
Thanks,
Sagar
View this message in context: http://osgeo-org.1803224.n2.nabble.com/GDAL-JAVA-problem-tp2147356p5630121.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
