[gdal-dev] Re: ERROR 4: ... is a grib file, but no raster dataset was successfully identified.
Hermann Peifer peifer at gmx.eu
Wed Oct 13 05:31:12 EDT 2010
Hello again.
I am still running into this error with gdalinfo:
$ gdalinfo HRES_ENS_2010101000+000.grib2
ERROR 4: HRES_ENS_2010101000+000.grib2 is a grib file, but no raster
gdalinfo failed - unable to open 'HRES_ENS_2010101000+000.grib2'.
However, other tools (wgrib2 and grib_ls from libgrib-api-tools) read
the same file without any problems, see below.
Any ideas? The file is here:
http://transfer.eea.europa.eu/download/07ae94812cbe4823600b4d5ae64aadca
Thanks in advance, Hermann
$ wgrib2 HRES_ENS_2010101000+000.grib2
1:0:d=2010101000:MASSDEN:surface:anl:ENS=hi-res ctl chemical=Water Vapour
2:675793:d=2010101000:MASSDEN:500 m above ground:anl:ENS=hi-res ctl
3:1351586:d=2010101000:MASSDEN:1000 m above ground:anl:ENS=hi-res ctl
4:2027379:d=2010101000:MASSDEN:3000 m above ground:anl:ENS=hi-res ctl
5:2703172:d=2010101000:MASSDEN:surface:anl:ENS=hi-res ctl
chemical=Nitrous Oxide
6:3378965:d=2010101000:MASSDEN:500 m above ground:anl:ENS=hi-res ctl
7:4054758:d=2010101000:MASSDEN:1000 m above ground:anl:ENS=hi-res ctl
8:4730551:d=2010101000:MASSDEN:3000 m above ground:anl:ENS=hi-res ctl
9:5406344:d=2010101000:MASSDEN:surface:anl:ENS=hi-res ctl chemical=Ammonium
10:6082137:d=2010101000:MASSDEN:500 m above ground:anl:ENS=hi-res ctl
chemical=Ammonium
11:6757930:d=2010101000:MASSDEN:1000 m above ground:anl:ENS=hi-res ctl
chemical=Ammonium
12:7433723:d=2010101000:MASSDEN:3000 m above ground:anl:ENS=hi-res ctl
chemical=Ammonium
13:8109516:d=2010101000:MASSDEN:surface:anl:ENS=hi-res ctl
chemical=Nitrogen Dioxide
14:8785309:d=2010101000:MASSDEN:500 m above ground:anl:ENS=hi-res ctl
15:9461102:d=2010101000:MASSDEN:1000 m above ground:anl:ENS=hi-res ctl
16:10136895:d=2010101000:MASSDEN:3000 m above ground:anl:ENS=hi-res ctl
17:10812688:d=2010101000:MASSDEN:surface:anl:ENS=hi-res ctl chemical=???
see code 4.230
18:11488481:d=2010101000:MASSDEN:500 m above ground:anl:ENS=hi-res ctl
chemical=??? see code 4.230
19:12164274:d=2010101000:MASSDEN:1000 m above ground:anl:ENS=hi-res ctl
20:12840067:d=2010101000:MASSDEN:3000 m above ground:anl:ENS=hi-res ctl
