[gdal-dev] gdaldem color-relief color_text_files
Joaquim Luis
jluis at ualg.pt
Tue Oct 19 13:57:37 EDT 2010
Even,
Thanks. It was when I wrote it long time ago. Now fixed.
> Joaquim,
> by the way the link to GDAL on Mirone home page
> (http://w3.ualg.pt/~jluis/mirone) is broken. It should point to
> http://gdal.org and not to http://remotesensing.org/gdal
> Le mardi 19 octobre 2010 12:08:14, Joaquim Luis a écrit :
>> Now that the ability to read GMT .cpt palettes was added to trunk I'll
>> make a little advertise on the Mirone's "Color Palette" tool.
>> It has over a hundred internal color scales and one can manipulate each
>> one of them with lifter and/or click-and-drags. At the end, the color
>> scale can be exported as continuous or discrete GMT palettes. It looks
>> like this
>> http://w3.ualg.pt/~jluis/mirone/files/ChangePalette2.html
>> Joaquim
>>> This isn't quite what you need, but for creating thematic colour
>>> schemes, http://colorbrewer2.org/ is a rather neat tool. I suppose it
>>> wouldn't be too much of a stretch to interpolate between the colours it
>>> generates for a full 256 pallette.
>>> -JD
>>> ________________________________
>>> From: gdal-dev-bounces at lists.osgeo.org
>>> [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Mark Millman
>>> Sent: 15 October 2010 01:17
>>> To: gdal-dev at lists.osgeo.org
>>> Subject: [gdal-dev] gdaldem color-relief color_text_files
>>> I am in need of some color_text files to use with the gdaldem
>>> color-relief utility to create color relief versions of Slope, Aspect,
>>> Roughness, TRI,& TPI maps. I seems to me that these ought to be pretty
>>> standard and as my skill set is on the developer side rather than the
>>> cartographer side of things I am hoping that some generous cartographer
>>> out there has already created some eye candy quality color_text_files
>>> for this purpose.
>>> Thanks in advance. Mark
>>> ______________________________________________________________________
>>> This email has been scanned for Virtalis Ltd by the MessageLabs Email
>>> Security System.
>>> gdal-dev mailing list
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
