[gdal-dev] Re: Testing Geospatial PDF support
Eli Adam
EAdam at co.lincoln.or.us
Tue Oct 19 15:10:18 EDT 2010
There are more geospatial pdfs available here:
http://nationalmap.gov/ustopo/index.html - then click on 'Download Maps
(Map Store)' on the left side.
Then you need to place a marker, then click the marker, then hit
download.
I've not worked with them very much yet.
Bests, Eli
>>> Even Rouault <even.rouault at mines-paris.org> 10/19/2010 11:45 AM
Brent,
I'm not sure what you find is wrong. What does gdalinfo returns ?
The PDF driver will reproject the coordinates of the GPTS array from
geographic into UTM 35N and try to build a geotransform matrix from
that. The
matrix may have rotating terms, so you likely need to use gdalwarp
afterwards
to make it look "straight". However I'm not 100% sure this is the
correct way
to interpret the the Adobe style georeferencing, but I didn't find a
better one
up to know. So if you or someone else have any clue...
Most geospatial PDFs I've found in the wild (such as the one of
cantopo) seem
to use the OGC Best Practice encoding.
Even
Le mardi 19 octobre 2010 20:11:13, Brent Fraser a écrit :
> Even,
> I've tested a couple of Geospatial PDFs with the code that's in
GDAL
> trunk.
> The Canadian topos work well (e.g.
ftp://ftp2.cits.rncan.gc.ca/pub/cantopo/50k_geopdf/085/b/cantopo_085b14_geo
> pdf.zip). They were produced using ESRI ArcMap 9.2.6.1500. I get a
> properly geo-referenced GeoTiff after running gdal_translate.
> I have another PDF produced by ArcMap10.0.0.2414. It has a main
map
> and a keymap. The strange thing is that even though the coordinate
> system is UTM Zone 35 , it has a transformation matrix with
geographic
> coordinates given. Here's a portion of the "dump" file:
> Item[4] : VP
> Type = array
> Item[0]:
> Type = dictionary
> Item[0] : Name = ÿþI (string)
> Item[1] : Measure
> Type = dictionary
> Item[0] : Subtype = GEO (name)
> Item[1] : LPTS
> Type = array
> Item[0]: 0 (int)
> Item[1]: 1 (int)
> Item[2]: 0 (int)
> Item[3]: 0 (int)
> Item[4]: 1 (int)
> Item[5]: 0 (int)
> Item[6]: 1 (int)
> Item[7]: 1 (int)
> Item[2] : GPTS
> Type = array
> Item[0]: 38.815000 (real)
> Item[1]: 23.644900 (real)
> Item[2]: 43.662600 (real)
> Item[3]: 23.387000 (real)
> Item[4]: 43.615000 (real)
> Item[5]: 31.889000 (real)
> Item[6]: 38.774900 (real)
> Item[7]: 31.540700 (real)
> Item[3] : GCS
> Type = dictionary
> Item[0] : WKT =
PROJCS["WGS_1984_UTM_Zone_35N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPH
EROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["De
gree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["Fal
se_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Me
ridian",27.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origi
> n",0.0],UNIT["Meter",1.0]] (string)
> Item[1] : Type = PROJCS (name)
> Item[4] : Type = Measure (name)
> Item[5] : Bounds
> Type = array
> Item[0]: 0 (int)
> Item[1]: 1 (int)
> Item[2]: 0 (int)
> Item[3]: 0 (int)
> Item[4]: 1 (int)
> Item[5]: 0 (int)
> Item[6]: 1 (int)
> Item[7]: 1 (int)
> Item[2] : Type = Viewport (name)
> Item[3] : BBox
> Type = array
> Item[0]: 3168 (int)
> Item[1]: 2433 (int)
> Item[2]: 3557 (int)
> Item[3]: 2127 (int)
> Item[1]:
> Type = dictionary
> Item[0] : Name = ÿþA (string)
> Item[1] : Measure
> Type = dictionary
> Item[1] : LPTS
> Type = array
> Item[0]: 0 (int)
> Item[1]: 1 (int)
> Item[2]: 0 (int)
> Item[3]: 0 (int)
> Item[4]: 1 (int)
> Item[5]: 0 (int)
> Item[6]: 1 (int)
> Item[7]: 1 (int)
> Item[2] : GPTS
> Type = array
> Item[0]: 40.190600 (real)
> Item[1]: 26.279300 (real)
> Item[2]: 40.767200 (real)
> Item[3]: 26.273100 (real)
> Item[4]: 40.769300 (real)
> Item[5]: 27.212000 (real)
> Item[6]: 40.192600 (real)
> Item[7]: 27.210200 (real)
> Item[3] : GCS
> Type = dictionary
> Item[0] : WKT =
> Item[5] : Bounds
> Type = array
> Item[0]: 0 (int)
> Item[1]: 1 (int)
> Item[2]: 0 (int)
> Item[3]: 0 (int)
> Item[4]: 1 (int)
> Item[5]: 0 (int)
> Item[6]: 1 (int)
> Item[7]: 1 (int)
> Item[3] : BBox
> Type = array
> Item[0]: 57 (int)
> Item[1]: 2465 (int)
> Item[2]: 3052 (int)
> Item[3]: 46 (int)
> The resulting GeoTiff has a scaling problem, I suspect related to
the
> transformation matrix.
> Any thoughts on that?
> Thanks!
> Brent Fraser
gdal-dev mailing list
gdal-dev at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/gdal-dev
