[gdal-dev] ESRI binary grids problem
Sebastian E. Ovide sebastian.ovide at gmail.com
Thu Oct 21 04:53:15 EDT 2010
thanks for that  Frank,
mounting a windows share folder with samba I can see the Overviews. Copying
the same files into a ext4 FS, the overviews are not detected. So I renamed
the .rrd and .aux files in undercapital (same name as the raster folders)
and now I can see the overview also under ext4.
about the errors:
ERROR 3: Attempt to read past EOF in
data/ie/rasters/ie_t02_q200//../info/arc.dir.
ERROR 4: Failed to open table .VAT
I have deleted (renamed) the info folder and now the errors are gone... just
wondering if I have lost any functionality...
On Wed, Oct 20, 2010 at 2:43 PM, Frank Warmerdam <warmerdam at pobox.com>wrote:
> Sebastian E. Ovide wrote:
>> Hi All
>> I've save a ESRI binary grid using ArcMAP (in Binary format) and using
>> gdalinfo it looks like the RRD files are not read...
> Sebastian,
> Unfortunately, it is hard for me to figure out much without access to
> the dataset.   For a counter example, I'll provide a trimmed gdalinfo
> report for an aigrid dataset where the .rrd's are used:
> Driver: AIG/Arc/Info Binary Grid
> Files: h_dem
>       h_dem.aux
>       h_dem.rrd
>       h_dem/vat.adf
>       h_dem/metadata.xml
>       h_dem/log
>       h_dem/w001001.adf
>       h_dem/dblbnd.adf
>       h_dem/hdr.adf
>       h_dem/w001001x.adf
>       h_dem/sta.adf
>       h_dem/prj.adf
> Size is 3602, 1802
> Coordinate System is:
> GEOGCS["WGS 84",
> Origin = (-180.099999999999994,90.100000000000023)
> Pixel Size = (0.100000000000000,-0.100000000000000)
> Corner Coordinates:
> Upper Left  (-180.1000000,  90.1000000) (180d 6' 0.00"W, 90d 6' 0.00"N)
> Lower Left  (-180.1000000, -90.1000000) (180d 6' 0.00"W, 90d 6' 0.00"S)
> Upper Right ( 180.1000000,  90.1000000) (180d 6' 0.00"E, 90d 6' 0.00"N)
> Lower Right ( 180.1000000, -90.1000000) (180d 6' 0.00"E, 90d 6' 0.00"S)
> Center      (   0.0000000,   0.0000000) (  0d 0' 0.00"E,  0d 0' 0.00"N)
> Band 1 Block=256x4 Type=Int16, ColorInterp=Undefined
>  Min=-405.000 Max=7512.000
>  NoData Value=-32768
>  Overviews: 899x449, 448x223, 223x110, 110x54
>  Metadata:
>    LAYER_TYPE=athematic
> Note the .aux and .rrd files listed in the file list above the grid
> directory.  Also note the "Overviews:" listed in the band description.
> The error report in yours about not being able to read the contents of
> the info directory are not uncommon and I wouldn't expect that to
> interefere
> with the .aux/.rrd access though I'm not sure there is no side effect.  You
> might try hiding your info directory temporarily to see if that helps.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101021/30979423/attachment.html
