[gdal-dev] Transforming MSG Native data into reflectances
Simon Proud srp at geo.ku.dk
Fri Oct 22 11:40:26 EDT 2010
Hi all,
I'm testing out GDAL for use with MSG data, and would like to convert data
from raw counts to reflectance/brightness temperatures.
I have succeeded in this with the HRIT data (by compiling GDAL with the
--with-msg option) but is it also possible to do this with the native format
(.nat)? I'm totally unfamiliar with the native format, so any advice would
be greatfully received!
Thanks.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Transforming-MSG-Native-data-into-reflectances-tp5662990p5662990.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
