[gdal-dev] How to generate tiles with multiple vrt's using GDAL
Vaish vaerabati at gmail.com
Mon Oct 25 15:43:40 EDT 2010
  How can I generate tiles using multiple VRT'S without any tranparent gaps
using gdal commands.
1. When I run the gdal2tiles command on the first VRT , it works well but when
I run gdal2tiles command on the second VRT and point to the same outfput
folder. The tiles are overwritten.
I do not want to merge files because it takes time . Need to do this for an
ongoing project. So everyday I can make VRT's and append to it.
Can anyone suggest a soloution to this?
Thanks,
Vaish
