[gdal-dev] Re: NITF JPEG2000/Kakadu vsisubfile/mechanism.
turtlewax
frankhevans at yahoo.com
Tue Oct 26 09:23:54 EDT 2010
Need to make the "jp2kakdataset" recognize vsisubfile. Guidance appreciated.
gdal_translate -of NITF -co IC=C8 foo.tif foo.ntf
Input file size is 5677, 2428
ERROR 4: `/vsisubfile/933_41351268,foo.ntf' not recognised as a supported
file format.
ERROR 1: Unable to open JPEG2000 image within NITF file.
Is the JP2KAK driver available?
ERROR 1: Kakadu Core Error:
Code-stream must start with an SOC marker!
Warning 6: Driver JP2KAK does not support PROFILE creation option
Warning 6: Driver JP2KAK does not support CODESTREAM_ONLY creation option
0...10...20...30...40...50...60...70...80...90...100 - done.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/NITF-JPEG2000-compression-and-Kakadu-tp4334019p5674585.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
