[gdal-dev] Issue with python bindings.
Ivan Willig
iwillig at gmail.com
Tue Oct 26 11:01:01 EDT 2010
Thanks Jason,
I will add my examples when I get a chance.
Ivan Willig
On Tue, Oct 26, 2010 at 10:59 AM, Jason Roberts <jason.roberts at duke.edu>wrote:
> Ivan, Frank,
> A month ago I started a gotchas page with Even Rouault that discusses this
> issue: http://trac.osgeo.org/gdal/wiki/PythonGotchas. If you have a
> moment, please consider adding your examples as other cases that cause the
> lifetime problem. Also (Frank) if there is any general advice you wish to
> add, it would be greatly appreciated.
> Best,
> Jason
> *From:* gdal-dev-bounces at lists.osgeo.org [mailto:
> gdal-dev-bounces at lists.osgeo.org] *On Behalf Of *Ivan Willig
> *Sent:* Tuesday, October 26, 2010 10:54 AM
> *To:* Frank Warmerdam
> *Cc:* gdal-dev at lists.osgeo.org
> *Subject:* Re: [gdal-dev] Issue with python bindings.
> Thanks Frank. That seems to be the issue. Whats the rule about this how
> long you should keep a reference. For example this causes the same issue.
> ds.GetLayer().GetFeature(0).GetGeometryRef().GetEnvelope()
> Which I am going to guess is because I should keep a reference to the
> geometry. Correct?
> Ivan Willig
> On Tue, Oct 26, 2010 at 10:44 AM, Frank Warmerdam <warmerdam at pobox.com>
> wrote:
> Ivan Willig wrote:
> Hi list,
> I am having an issues with using the python swig based bindings. I am on
> Fedora 13 using the default gdal rpm, which is at version 1.6.2. My issue is
> when i stack method calls. For example when I do the following:
> ogr.Open("/home/ivan/dev/bigapps/data/nyco.shp").GetLayer().GetFeature(0)
> I get a Segmentation fault. Here are the results of strace
> http://paste.pocoo.org/show/281682/. What am I doing wrong? Should I just
> hand compile a new version of gdal? Or is this not an advised usage of the
> python bindings? A limitation in swig? Thanks for your help.
> Ivan,
> I believe the problem is object lifetimes. Keep a reference to the
> datasource around until you are done with the feature(s).
> ds = ogr.Open("/home/ivan/dev/bigapps/data/nyco.shp")
> feat = ds.GetLayer().GetFeature(0)
> feat = None
> ds = None
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101026/edebfe3e/attachment.html
