[gdal-dev] gdalinfo and scale/offset
Kyle Shannon ksshannon at gmail.com
Thu Oct 28 14:51:10 EDT 2010
Joaquim,
With my code I wrote today, the offset and scale are set on the
GDALRasterBand itself.  If I do the following:
gdal_translate lixo.grd lixo.tif
gdalinfo lixo.tif -mm
I get:
Driver: GTiff/GeoTIFF
Files: lixo.tif
       lixo.tif.aux.xml
Size is 21, 21
Coordinate System is `'
Origin = (-10.500000000000000,10.500000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Metadata:
  NC_GLOBAL#Conventions=COARDS/CF-1.0
  NC_GLOBAL#title=lixo.grd
  NC_GLOBAL#history=grdmath -R-10/10/-10/10 -I1 X Y MUL = lixo.grd
  NC_GLOBAL#GMT_version=4.5.4
  z#long_name=z
  z#_FillValue=nan
  z#actual_range=-1, 1
  z#scale_factor=0.01
  x#long_name=x
  x#actual_range=-10, 10
  y#long_name=y
  y#actual_range=-10, 10
Image Structure Metadata:
  INTERLEAVE=BAND
Corner Coordinates:
Upper Left  ( -10.5000000,  10.5000000)
Lower Left  ( -10.5000000, -10.5000000)
Upper Right (  10.5000000,  10.5000000)
Lower Right (  10.5000000, -10.5000000)
Center      (   0.0000000,   0.0000000)
Band 1 Block=21x21 Type=Float32, ColorInterp=Gray
    Computed Min/Max=-100.000,100.000
  NoData Value=nan
  Offset: 0,   Scale:0.01
  Metadata:
    NETCDF_VARNAME=z
where you can see the offset and scale reported at the band level.  This is
not just metadata anymore, it belongs to GDALRasterBand.
if I run:
gdal_translate -unscale lixo.grd lixo_uscale.tif
gdalinfo -mm lixo_unscale.tif
Files: lixo_uscale.tif
       lixo_uscale.tif.aux.xml
Size is 21, 21
Metadata:
  z#long_name=z
  z#_FillValue=nan
  z#scale_factor=0.01
  x#long_name=x
  y#long_name=y
  INTERLEAVE=BAND
Corner Coordinates:
    Computed Min/Max=-1.000,1.000
  NoData Value=nan
  Metadata:
    NETCDF_VARNAME=z
The data in the tif is unscaled or unpacked.
I don't know if this is clear, I apologize for all the snippets. I, like
Even, have no strong feelings for gdalinfo reporting scaled/unscaled data.
kss
Kyle Shannon
Physical Science Technician
RMRS Fire Sciences Lab
Fire, Fuels & Smoke - RWU 4405
5775 Highway 10 W.
Missoula, MT 59808
(406)829-6954
kshannon at fs.fed.us
On Thu, Oct 28, 2010 at 12:35 PM, Joaquim Luis <jluis at ualg.pt> wrote:
> Even
> Thanks for pointing into this that I was not aware of as it would be the
> main point of my answer to Kyle's question.
> But still, as it is referred in the ticket (sorry for lousy formatting but
> I never learn how to do it better) the main issue occurred in the conversion
> to another format (geotiff for that matter). So though an option exists
> ('unscale') to account for offset/scale the natural expectancy is that the
> conversion does not change the data values.
> Redoing the tickets example we can see (not shown than because I thought
>  it of lesser interest)
> C:\SVN\mironeWC\src_C\t>gdalinfo lixo.tiff -mm
> Files: lixo.tiff
> Size is 21, 21
> Metadata:
>  z#long_name=z
>  z#_FillValue=1.#QNAN0e+000
>  z#scale_factor=0.01
>  x#long_name=x
>  y#long_name=y
>  INTERLEAVE=BAND
> Corner Coordinates:
> It's true that we can still see a trace of the previous info about the
> scale
>  z#scale_factor=0.01
> but a user would need to be very very attentive to realize that and to know
> that the data values were off by an 0.01 factor.
> I think that in these situations the scale factor would better be applied
> by default (like with the gdal_info example)
> Joaquim
>  Kyle,
>> Frank added in GDAL 1.7 a '-unscale' option to gdal_translate, so people
>> can
>> always use gdal_translate -unscale to apply the offset and scale (they can
>> even
>> do that do a VRT file to save disk space), and then use gdalinfo on the
>> result.
>> Extract from the gdal_translate man page:
>> "-unscale : Apply the scale/offset metadata for the bands to convert
>> scaled
>> values to unscaled values.  It is also often necessary to reset the output
>> datatype with the -ot switch."
>> Is there a need for such an option in gdalinfo ? I have no strong opinion
>> about this. An issue I see is that usually -stats record the computed
>> stats in
>> a .aux.xml file for later retrieval. The interaction with a -unscale
>> option
>> would be tricky... What happens if the user computes with -unscale and
>> then do
>> gdalinfo without it... Or the other way round.
>> Le jeudi 28 octobre 2010 19:58:55, Kyle Shannon a écrit :
>>> Hello,
>>> I have been working  on ticket #3797.  In the example given, gdalinfo is
>>> the calling the netcdf driver.  I agree with Frank's opinion on this in
>>> ticket #1660:
>>> Note that GDALRasterBand has methods to get the offset and scale. The
>>> normal
>>>> GDAL practice would be to return them via those methods - not to apply
>>>> them on the fly. Then it is up to the caller to do so if they wish.
>>> gdal shouldn't be in charge of scaling the data to what may be a
>>> different
>>> data type, or unpacking it.  But in this case, gdalinfo is the caller.
>>> Should the functionality of the scaling be added to gdalinfo?  Maybe
>>> optionally reporting the stats as scaled data?  Any thoughts?
>>> Kyle Shannon
>>> Fire, Fuels&  Smoke - RWU 4405
>>> 5775 Highway 10 W.
>>> Missoula, MT 59808
>>> (406)829-6954
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101028/0c686cf8/attachment-0001.html
