[gdal-dev] Worldfile creation inconsistency with gdal_translate
NeilJ
neil.jakeman at findmaps.co.uk
Fri Oct 29 05:59:57 EDT 2010
Please can someone explain to me why I get the message "Waring 6: Driver
JPEG does not support WORDFILE creation option" when using gdal_translate on
a windows command line (FW Tools 2.4.7), when running:
gdal_translate -of JPEG -co WORDLFILE=YES -a_srs EPSG:27700 HP40SE.tif
The tif in question has the following details:
Driver: GTiff/GeoTIFF
Files: HP40SE.tif
Size is 5000, 5000
Coordinate System is:
PROJCS["unnamed",
GEOGCS[,
DATUM["unknown",
SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","27700"]]
Origin = (445000.000000000000000,1205000.000000000000000)
Pixel Size = (1.000000000000000,-1.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=DEFLATE
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 445000.000, 1205000.000)
Lower Left ( 445000.000, 1200000.000)
Upper Right ( 450000.000, 1205000.000)
Lower Right ( 450000.000, 1200000.000)
Center ( 447500.000, 1202500.000)
Band 1 Block=5000x1 Type=Byte, ColorInterp=Red Band 2 Block=5000x1
Type=Byte, ColorInterp=Green Band 3 Block=5000x1 Type=Byte, ColorInterp=Blue
I am very confused by the worldfile=yes option as I have used it before on
other conversions without a problem.
Any advice on when and why this does/doesn't work?
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Worldfile-creation-inconsistency-with-gdal-translate-tp5685831p5685831.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
