[gdal-dev] _gdal_array not found
Christopher Barker
Chris.Barker at noaa.gov
Fri Oct 29 12:18:21 EDT 2010
On 10/29/10 3:36 AM, Jorge Arévalo wrote:
> I find several files missing in the newer one (2.7). Files like
> "_gdal_array.py", "_gdal_array.pyc", "_gdalconst.py",
> "_gdal_array.so", "_gdalconst.so", "_gdal.py", "_gdal.pyc",
> "_gdal.so", and so on. All the missing files starting with "_"
> The newer installation (2.7) was created from sources, building python
> 2.7 and GDAL 1.7.2 (with "configure --with-python&& make&& make
> install"). The previous installation (2.4) was created from package
> manager (Suse YaST).
Something went wrong with your build -- check the messages carefully.
And yes, installing numpy from source should give you what you need.
Do make sure that you are using the same version of python for everything.
HTH,
-Chris
Christopher Barker, Ph.D.
Oceanographer
Emergency Response Division
NOAA/NOS/OR&R (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
