[gdal-dev] swig generated files for Perl bindings removed from
repository
Ari Jolma
ari.jolma at gmail.com
Wed Sep 1 13:58:38 EDT 2010
On 08/19/2010 04:20 PM, Frank Warmerdam wrote:
> Ari,
> I agree, you are welcome to remove the perl bindings from the repository.
> I see that the mkgdaldist.sh script is already regenerating the perl
> (and C#) bindings when release and nightly distributions are prepared.
> If it has not already been done, you should try to make the situation
> clear in the documentation.
I created a new section for the foreign function interface (aka
bindings, aka wrappers) to http://trac.osgeo.org/gdal/wiki/BuildHints
I wrote a short page for Perl
If there are hints for Python, C#, Java or other interfaces, they should
be linked to the BuildHints page as it is the entry page for the build
documentation.
Regards,
Ari
