[gdal-dev] Re: GDALINFO cannot pipe to text file
Hermann Peifer
peifer at gmx.eu
Fri Sep 3 02:32:04 EDT 2010
On 03/09/2010 02:27, AusRod wrote:
Same here:
$ GDALINFO file.tif > textfile
-bash: GDALINFO: command not found
But there is an easy way out. See below. Hermann
$ gdalinfo file.tif > textfile
$ cat textfile
Driver: GTiff/GeoTIFF
Files: file.tif
Size is 4850, 4150
Coordinate System is:
PROJCS["ETRS_1989_LAEA_L52_M10",
GEOGCS["European_Terrestrial_Reference_System_1989",
DATUM["European_Terrestrial_Reference_System_1989",
SPHEROID["GRS 1980",6378137,298.2572221010002,
AUTHORITY["EPSG","7019"]],
AUTHORITY["EPSG","6258"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Lambert_Azimuthal_Equal_Area"],
PARAMETER["latitude_of_center",52],
PARAMETER["longitude_of_center",10],
PARAMETER["false_easting",4321000],
PARAMETER["false_northing",3210000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]]]
Origin = (2555000.000000000000000,5500000.000000000000000)
Pixel Size = (1000.000000000000000,-1000.000000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
INTERLEAVE=BAND
Corner Coordinates:
Upper Left ( 2555000.000, 5500000.000) ( 34d 7'12.64"W, 67d17'7.44"N)
Lower Left ( 2555000.000, 1350000.000) ( 8d54'24.14"W, 33d13'50.38"N)
Upper Right ( 7405000.000, 5500000.000) ( 72d57'42.08"E, 58d55'2.50"N)
Lower Right ( 7405000.000, 1350000.000) ( 42d 7'32.17"E, 29d19'21.50"N)
Center ( 4980000.000, 3425000.000) ( 19d58'18.08"E, 53d31'26.07"N)
Band 1 Block=256x256 Type=Int16, ColorInterp=Gray
NoData Value=-9999
