[gdal-dev] Reading MXD files
Paolo Corti pcorti at gmail.com
Sat Sep 4 17:44:16 EDT 2010
>    Im wondering if there is any way to read MXD files in ether gdal or some other python based extension. I'm not looking for the raster data for the files only the filename/SDE name of the layer and the name of the layer in the MXD file. Is there any easy way to pull this information out of the MXD?
I think your only option is to use the ArcGis Python library, but you
need a license for doing so
Paolo
