[gdal-dev] Reading MXD files
    Lucena, Ivan
    ivan.lucena at pmldnet.com
    Fri Sep  3 20:36:06 EDT 2010
Ben,
There are some interfaces on the ArcObject package that let you not exactly *ready* the MXD but you
can get some useful information from the document. I believe that you can access the ArcObject COM
API in ArcGIS 10 or 9 by using the win32com.client.Dispatch() the same way as you can load the
"esriGeoprocessing.GpDispatch.1". You can use the tools on PythonWin to browse to all the available
ArcGIS components.
 >>> import win32com.client
 >>> arcobj = win32com.client.Dipath("< What should goes here ? >")
It is only a wild guess, I am not even running Windows now to do a quick test, but I hope it would
help you.
Ivan
Benjamin Welton wrote:
>  Can you do that with ArcGIS 9.3? i was under the impression from the
> doc's/forums that it's only available in the arcpy package in 10.
> Ben
> On 9/4/2010 5:44 PM, Paolo Corti wrote:
>>>     Im wondering if there is any way to read MXD files in ether gdal
>>> or some other python based extension. I'm not looking for the raster
>>> data for the files only the filename/SDE name of the layer and the
>>> name of the layer in the MXD file. Is there any easy way to pull this
>>> information out of the MXD?
>> I think your only option is to use the ArcGis Python library, but you
>> need a license for doing so
>> Paolo
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
