[gdal-dev] About new GDAL/OGR drivers
Peter Baumann p.baumann at jacobs-university.de
Mon Sep 6 14:33:51 EDT 2010
...plus this GDAL driver:
* rasdaman raster database ( http://gdal.org/frmt_rasdaman.html ) :
retrieval and processing of 2-D extracts from multi-dimensional raster
data sets.
-Peter
On 09/06/2010 08:27 PM, Even Rouault wrote:
> Hi all,
> I've neglected to mention a few of the GDAL/OGR drivers that I have recently
> added into trunk since 1.7 release. For those that like doing early testing
> and write useful bug reports so that those new drivers are in shape for the
> 1.8.0 release, here's a summary :
> GDAL drivers :
> * HF2/HFZ ( http://gdal.org/frmt_hf2.html ) : heightfield raster datasets that
> can be compressed. Read/write support.
> * JP2OpenJPEG ( http://gdal.org/frmt_jp2openjpeg.html ) : another (the 5th!)
> JPEG2000 driver, based on the open-source OpenJpeg library (BSD-licenced).
> More potential than Jasper with big images, but depends on an (yet) unreleased
> development branch of OpenJpeg. Read/write support.
> * XYZ ( http://gdal.org/frmt_xyz.html ) : to access simple gridded ASCII files.
> Read/write support.
> * GeoPDF ( http://gdal.org/frmt_geopdf.html ) : to extract both georeferencing
> and rasterize PDF documents, that have georeferencing encoded in either of the
> 2 current existing ways : the OGC GeoPDF encoding best practice (promoted by
> TerraGo), or according to the Adobe Supplement to ISO 32000. Read-only, based
> on poppler library (GPL-licenced)
> OGR drivers :
> * GPSBabel ( http://gdal.org/ogr/drv_gpsbabel.html ) : leverages the
> capabilities of the GPSBabel utility (GPL-licenced) to read/write many GPS file
> formats.
> * OpenAir ( http://gdal.org/ogr/drv_openair.html ) and SUA (
> http://gdal.org/ogr/drv_sua.html ) : 2 fairly equivalent and special-purpose
> drivers to read text files describing Special Use Airspaces.
> * PDS ( http://gdal.org/ogr/drv_pds.html ) : another fairly specialized driver
> to extract tabular information from NASA PDS  (Planetary Data Systems) files
> * PGDump ( http://gdal.org/ogr/drv_pgdump.html ) : I believe I alrealdy
> mentionned that one. A write-only driver to generate SQL dump files that can be
> later injected into a live PostgreSQL instance. More or less similar to
> PostGIS shp2pgsql utility
> * WFS ( http://gdal.org/ogr/drv_wfs.html ) : a WFS/WFS-T client that can read
> and write OGC WFS 1.0.0 and 1.1.0 services.
> The GML driver was also significantly upgraded, in particular to support more
> GML3 geometries, more complex documents with non-flat structures and various
> tweaks that help reading some GML application schemas (CityGML, AIXM) etc...
> For more details about that... and the work done by all the others GDAL
> contributors, you can have a look at the preliminary NEWS :
> http://trac.osgeo.org/gdal/browser/trunk/gdal/NEWS
> How testing those new stuff ?
> - Unix/Linux users : checkout GDAL svn trunk (or daily snapshot from
> http://gdal.org/daily/ ), configure, make, make install ;-)
> - Windows users : build from source, or use for example Tamas Szekeres' daily
> builds at http://vbkto.dyndns.org/sdk/  (Note that those builds don't
> currently include JP2OpenJPEG and GeoPDF due to the external dependencies). I
> believe that gdal-dev in osgeo4w has also been recently updated with a
> 1.8.0dev snapshot.
> Have fun,
> Even
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Dr. Peter Baumann
  - Professor of Computer Science, Jacobs University Bremen
    www.faculty.jacobs-university.de/pbaumann
    mail: p.baumann at jacobs-university.de
    tel: +49-421-200-3178, fax: +49-421-200-493178
  - Executive Director, rasdaman GmbH Bremen (HRB 147737)
    www.rasdaman.com, mail: baumann at rasdaman.com
    tel: 0800-rasdaman, fax: 0800-rasdafax, mobile: +49-173-5837882
"Si forte in alienas manus oberraverit hec peregrina epistola incertis ventis dimissa, sed Deo commendata, precamur ut ei reddatur cui soli destinata, nec preripiat quisquam non sibi parata." (mail disclaimer, AD 10xx)
