[gdal-dev] Gdal nodata Complex value
Even Rouault even.rouault at mines-paris.org
Tue Sep 7 13:27:05 EDT 2010
Shawn,
The nodata value at the band level (GDALRasterBand::GetNoDataValue() /
SetNoDataValue()) is a real number, so there's no complete solution. Usually
parts of the application that take into account the real part of complex
numbers and compare it to the nodata value to determine if the pixel is nodata
or not.
There's an exception however in the warping code where you can pass a nodata
value formed of a real and imaginary part. See
http://gdal.org/structGDALWarpOptions.html
Le mardi 07 septembre 2010 17:23:57, Shawn Gong a écrit :
> Hi list,
> How do you set Gdal nodata in Complex? Would someone give me an example?
> Thanks,
> Shawn
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
