[gdal-dev] Invalid geometry reading from Oracle via OGR OCI driver
Niccolo Rigacci
niccolo at rigacci.org
Thu Sep 9 09:44:47 EDT 2010
In an Oracle Spatial DB I have a geometry like this:
MULTIPOLYGON = (((POLYGON), (HOLE)), ((POLYGON), (HOLE)))
When I dump the geometry via ogrinfo, I get an invalid geometry:
MULTIPOLYGON = (((POLYGON)), ((POLYGON)), ((POLYGON)), ((POLYGON)))
The dump is done with:
ogrinfo "OCI:..." table_name
The same problem results when I import the Oracle geometry into a
Postgres database via ogr2ogr. The resulting geometry is invalid.
Strange enough, if I convert the same Oracle geometry into a
shapefile, the result IS valid: two polygons with one hole
each. The conversion is made with:
ogr2ogr -f "ESRI Shapefile" shapefile "OCI:..."
I noticed also that the polygons into the shapefile are
clock-wise inverted respect the original Oracle ones, but the
geometry is valid.
I'm using GDAL/OGR 1.6.3.
Am I missing some OGR parameter?
Is this a known bug fixed in newer versions?
Thank you very much for any hints.
Niccolo Rigacci
Firenze - Italy
