[gdal-dev] Adding transaction support to the CPL ODBC layer
Tamas Szekeres
szekerest at gmail.com
Thu Sep 9 15:21:45 EDT 2010
Folks,
I've created an OGR driver to provide read/write support for accessing the
MS SQL 2008+ spatial databases. I would be in favour of including this
driver in SVN trunk soon.
This driver use the current CPL ODBC implementation to access the server,
however it should somewhat be extended to support transactions at ODBC
level.
For this reason I've created a ticket
http://trac.osgeo.org/gdal/ticket/3745and added the patch related to
this common code.
Any objections to apply these additions? I'm not sure it this change is
large enough to write up an RFC on this, but I would do so if required.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100909/f82c2d00/attachment.html
