[gdal-dev] Creating shape file from csv with double quotes in
attribute
Paolo Corti
pcorti at gmail.com
Fri Sep 10 13:52:35 EDT 2010
> Hi,
> I have a query on creating shapefile from csv. I am not sure if this is the correct forum for it. Thought I should try it anyway.
> I have a csv file consisting of lat/lon and an attribute with double quotes like this:
> "<a href="http://data.nodc.noaa.gov/thredds/dodsC/gtspp/atlantic/2010/07/9670278.nc.html" target="_blank">Data URL</a>"
> When I create the shape file from this file using a vrt file, the shape file has this value for the attribute:
> <a href=http://data.nodc.noaa.gov/thredds/dodsC/gtspp/atlantic/2010/07/9670278.nc
> As you can see, the double quotes are gone and the attribute is truncated. How do I overcome this problem? Any help is appreciated.
Oops I read your questions too quickly.
In any case I would store in one field the text and in another one the
url after preprocessing the string
Best regards
P
