[gdal-dev] TIFF write and comparison
Akhil Jaggarwal
axj4159 at cs.rit.edu
Sat Sep 11 14:01:37 EDT 2010
I just started using the GDAL C API.
I wrote some code that compares pixel values of 4 equally sized
GeoTIFFs, and depending on the values, writes the output to an output
TIFF.
I'd like to ask if:
1) I'm doing it the correct way, specifically if I'm writing the
pixels the correctly.
2) Is using CreateCopy() an ideal method to write projection
information? Should I write using Create() instead? tiffinfo output of
the output tiff does not state all the projection information using
CreateCopy().
Thanks.
Here's the code:
#include "/usr/include/gdal/gdal.h"
#include "/usr/include/gdal/cpl_conv.h" /* for CPLMalloc() */
#include "/usr/include/gdal/cpl_string.h" // for createcopy()
int main(int argc, char **argv)
GDALDatasetH hDataset;
GDALDatasetH hDataset2;
GDALDatasetH hDataset3;
GDALDatasetH hDataset4;
// output tiff
GDALDatasetH hDestDS;
GDALAllRegister();
hDataset = GDALOpen( argv[1], GA_ReadOnly );
hDataset2 = GDALOpen( argv[2], GA_ReadOnly );
hDataset3 = GDALOpen( argv[3], GA_ReadOnly );
hDataset4 = GDALOpen( argv[4], GA_ReadOnly );
GDALDriverH hDriver;
GDALDriverH hDriver2;
GDALDriverH hDriver3;
GDALDriverH hDriver4;
// array to hold projection data
double adfGeoTransform[6];
hDriver = GDALGetDatasetDriver( hDataset );
hDriver2 = GDALGetDatasetDriver( hDataset2 );
hDriver3 = GDALGetDatasetDriver( hDataset3 );
hDriver4 = GDALGetDatasetDriver( hDataset4 );
// hDriver = GDALGetDatasetDriver( hDataset2 );
// hDriver = GDALGetDatasetDriver( hDataset3 );
// hDriver = GDALGetDatasetDriver( hDataset4 );
printf( "Driver: %s/%s\n",
GDALGetDriverShortName( hDriver ),
GDALGetDriverLongName( hDriver ) );
/* ====================== get TIFF attributes ========================= */
printf( "Size is %dx%dx%d\n",
GDALGetRasterXSize( hDataset ),
GDALGetRasterYSize( hDataset ),
GDALGetRasterCount( hDataset ) );
/* printf( "Size is %dx%dx%d\n",
GDALGetRasterXSize( hDataset2 ),
GDALGetRasterYSize( hDataset2 ),
GDALGetRasterCount( hDataset2 ) );
if( GDALGetProjectionRef( hDataset ) != NULL )
printf( "Projection (dataset1) is `%s'\n", GDALGetProjectionRef( hDataset ) );
/* if( GDALGetProjectionRef( hDataset2 ) != NULL )
printf( "Projection (dataset2) is `%s'\n", GDALGetProjectionRef(
hDataset2 ) );
if( GDALGetGeoTransform( hDataset, adfGeoTransform ) == CE_None )
printf( "Origin = (%.6f,%.6f)\n",
adfGeoTransform[0], adfGeoTransform[3] );
printf( "Pixel Size = (%.6f,%.6f)\n",
adfGeoTransform[1], adfGeoTransform[5] );
/* ================= Fetch raster data to read on later ================*/
// fetching raster data
GDALRasterBandH hBand;
GDALRasterBandH hBand2;
GDALRasterBandH hBand3;
GDALRasterBandH hBand4;
int nBlockXSize, nBlockYSize;
int bGotMin, bGotMax;
double adfMinMax[2];
hBand = GDALGetRasterBand( hDataset, 1 );
hBand2 = GDALGetRasterBand( hDataset, 1 );
hBand3 = GDALGetRasterBand( hDataset, 1 );
hBand4 = GDALGetRasterBand( hDataset, 1 );
GDALGetBlockSize( hBand, &nBlockXSize, &nBlockYSize );
printf( "Block=%dx%d Type=%s, ColorInterp=%s\n",
nBlockXSize, nBlockYSize,
GDALGetDataTypeName(GDALGetRasterDataType(hBand)),
GDALGetColorInterpretationName(
GDALGetRasterColorInterpretation(hBand)) );
adfMinMax[0] = GDALGetRasterMinimum( hBand, &bGotMin );
adfMinMax[1] = GDALGetRasterMaximum( hBand, &bGotMax );
if( ! (bGotMin && bGotMax) )
GDALComputeRasterMinMax( hBand, TRUE, adfMinMax );
printf( "Min=%.3fd, Max=%.3f\n", adfMinMax[0], adfMinMax[1] );
if( GDALGetOverviewCount(hBand) > 0 )
printf( "Band has %d overviews.\n", GDALGetOverviewCount(hBand));
if( GDALGetRasterColorTable( hBand ) != NULL )
printf( "Band has a color table with %d entries.\n",
GDALGetColorEntryCount(
GDALGetRasterColorTable( hBand ) ) );
/* ================== check if format supports createcopy() ===== */
const char *pszFormat = "GTiff";
hDriver = GDALGetDriverByName( pszFormat );
char ** papszMetadata;
if (hDriver == NULL )
exit(1);
papszMetadata = GDALGetMetadata( hDriver, NULL );
if( CSLFetchBoolean( papszMetadata, GDAL_DCAP_CREATE, FALSE ) ) {
printf( "Driver %s supports Create() method.\n", pszFormat );
if( CSLFetchBoolean( papszMetadata, GDAL_DCAP_CREATECOPY, FALSE ) ) {
printf( "Driver %s supports CreateCopy() method.\n", pszFormat );
/* ================== Read raster data ========================*/
// for class tiff
unsigned char * pafScanline;
// for slope tiff
short int * pafScanline2;
// for elevation tiff
short int * pafScanline3;
// for wb1 tiff
short int * pafScanline4;
const char *pszDestFileName = "out_142029.tif";
hDestDS = GDALCreateCopy(hDriver, pszDestFileName, hDataset, FALSE,
NULL, NULL, NULL );
int nxSize = GDALGetRasterBandXSize( hBand );
int nySize = GDALGetRasterBandYSize( hBand );
printf("raster band xSize: %d\n", nxSize);
printf("raster band ySize: %d\n", nySize);
int rule1 = 5;
int rule2 = 3;
// pafScanline is a void pointer
void *change1 = &rule1;
void *change2 = &rule2;
// allocate buffer to hold pixel data
// classification
pafScanline = (unsigned char *)CPLMalloc(sizeof(unsigned char)*nxSize);
// slope
pafScanline2 = (short int *)CPLMalloc(sizeof(short int)*nxSize);
// dem-elevation
pafScanline3 = (short int *)CPLMalloc(sizeof(short int)*nxSize);
// wb1
pafScanline4 = (short int *)CPLMalloc(sizeof(short int)*nxSize);
// erwflag, nxoff, nyoff, nxsize, nysize, pdata, nbufxsize, nbufysize,
// ebuftype, npixelspace, nlinespace
//nBlockXSize, nBlockYSize,
int i,j;
// compare and read datasets, change values accordingly
for(i = 0; i < nxSize; i++) {
for(j = nySize; j < 5; j++) {
GDALRasterIO(hBand, GF_Read, 0,0, i, j, pafScanline,
i, j,
GDT_Byte,
0, 0);
GDALRasterIO(hBand, GF_Read, 0,0, i, j, pafScanline2,
i, j,
GDT_Int16,
0, 0);
GDALRasterIO(hBand, GF_Read, 0,0, i, j, pafScanline3,
i, j,
GDT_Int16,
0, 0);
GDALRasterIO(hBand, GF_Read, 0,0, i, j, pafScanline4,
i, j,
GDT_Int16,
0, 0);
// read datasets, compare data and write
if ( (pafScanline2[j] > 6 || pafScanline3[j] > 950) &&
pafScanline[j] == 2) {
GDALRasterIO( hDestDS, GF_Write, 0,0, i,j,
change1, i, i, GDT_Byte, 0,0);
else if( (pafScanline4[j] < -700) &&
pafScanline[j] == 6 ) {
change2, i, i, GDT_Byte, 0,0);
else if( (pafScanline2[j] > 6) && pafScanline[j] == 3 ) {
else if((pafScanline3[j]>1500) && pafScanline[j] == 6) {
else
&pafScanline[j], i, i, GDT_Byte, 0,0);
// printf("%u\n", pafScanline[j]);
// printf("width of pixels in this band: %d\n", );
CPLFree(pafScanline);
CPLFree(pafScanline2);
CPLFree(pafScanline3);
CPLFree(pafScanline4);
GDALClose(hDataset);
GDALClose(hDataset2);
GDALClose(hDataset3);
GDALClose(hDataset4);
GDALClose(hDestDS);
// CSLDestroy(argv);
GDALDestroyDriverManager();
return 0;
