[gdal-dev] Copy only georeference between two images
christian.mueller at nvoe.at christian.mueller at nvoe.at
Mon Sep 13 10:52:08 EDT 2010
Do you have the georeference information included in your image file
(geotiff for example) or do you have an extra world file containing 6
lines of numbers.
In the second case, it is easy.
Quoting canduc17 <candini at meeo.it>:
> One simple question:
> I have two identical images, exept for their their georeferentiation. They
> represent the same scene, their sizes are identical, but one of them has a
> correct UTM georeferentiation and the second one hasn't.
> In which way can I copy and paste the correct georeferentiation from one to
> another?
> Thanks in advance.
> http://osgeo-org.1803224.n2.nabble.com/Copy-only-georeference-between-two-images-tp5526582p5526582.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
