[gdal-dev] Re: Copy only georeference between two images
Ralf Suhr
Ralf.Suhr at itc-halle.de
Tue Sep 14 06:46:41 EDT 2010
You have a wrong georeferentiation? I think it is better to transform this
"wrong" georeferentiation.
The quick way: strip geotiff information with mogrify -strip. Now the
information from world file will be used.
Gr
Ralf
Am Dienstag 14 September 2010 12:23:08 schrieb canduc17:
> My files have both the georeferentiation, but one is correct and the other
> one is wrong.
> And the georeferentiation is INSIDE the geotiff file, not in a separated
> .tfw file.
> I would like to obtain only one file as output. To have only one GEOTiff
> image with the corrected georef...
