[gdal-dev] RFC28 OGR SQL Expressions now in trunk
Tue Sep 14 21:00:15 EDT 2010
Smith, Michael ERDC-CRREL-NH wrote:
> Frank,
> I was testing accesing the OGR_STYLE value from a kmz file using the LIBKML
> driver. Previously this had worked.
> u4rt9mds at maps:/htdocs/dhs/marine$ ogr2ogr -f OCI
> oci:"user/pass at tns:marinetest MarineTraffic.kmz -nln MArineTest3 -lco dim=2
> -lco srid-8265 -lco launder=yes -lco precision=no -sql "select *, ogr_style
> from 0"
> OGR: OGROpen(MarineTraffic.kmz/0x13bb63a0) succeeded as LIBKML.
> ERROR 1: SQL Expression Parsing Error: syntax error
Mike,
The problem seems to be the table named 0 rather than the ogr_style
portion.  Currently well formed identifiers must start with a letter or
an underscore, not a numeric digit.  You can however quote it.
So 'select *, ogr_style from "0"' should work.
This is definitely a backward compatability issue, but it isn't clear to me
whether I ought to try and change it or not.  Thoughts welcome.
Best regards,
