[gdal-dev] Re: TIFF write and comparison
Akhil Jaggarwal axj4159 at cs.rit.edu
Tue Sep 14 23:07:14 EDT 2010
Any comments/suggestions on this issue would be immensely helpful!
I'm storing the pixel values in a buffer like this:
 pafScanline = (short int*)CPLMalloc(sizeof(short int)*nxSize*nySize);
I can read the data alright. The call to GDALRasterIO is being made
correctly, which I do with:
GDALRasterIO(hBand, GF_Read, 0, 0, nxSize, nySize,
                        pafScanline,
                        nxSize,nySize,
                        GDT_Int16,
                        0, 0);
However, when it comes to the part of writing a pixel data to an
output file, the call to GDALRasterIO fails:
for(i = 0; i < nySize; i++) {
                for(j = 0; j < nxSize; j++) {
                        if( CE_Failure == GDALRasterIO( hDestDS,
GF_Write, 0, 0, j, i,
                          change1, j, i , GDT_Int16, 0,0) ) {
                                  printf("Write Error!");
                                  return 1;
Where change1 is a variable to hold pixel data that I want to change.
It's declared in the following manner:
short int*change1;
change1 = malloc(sizeof(short int));
*change1 = 1;
I can't get what exactly am I missing. The file i'm using is a tiled,
16 bit signed TIFF.
How do I change the value at a pixel location?
Thanks!
On Mon, Sep 13, 2010 at 11:54 PM, Akhil Jaggarwal <axj4159 at cs.rit.edu> wrote:
> Hi,
> Thank you for the reply.
> Calls to GDALRasterIO() are OK. Which I assume in a line interleaved
> format look like this:
>  GDALRasterIO(hBand, GF_Read, 0,0, i, j, pafScanline,
>                        nBlockXSize, nBlockYSize,
>                        GDT_Int16,
>                        0, 0);
> Is that correct?
> Also, the statement: if(pafScanline[j] == pixel_value), is that a
> correct way to check if a pixel value at the jth col is equal to some
> constant?
> pafScanline is declared as follows: short int * pafScanline. In the
> API, pdata is a void *.
> Is this way to substitute the value of a pixel (of short int type)
> according to a rule, and then writing the pixel back to the TIFF a
> correct way? -
> short int rule1 = 1;
> void *change = malloc(sizeof(short int));
> change1 = &rule1;
> GDALRasterIO( hDestDS, GF_Write, 0,0, i,j, change1,
> nBlockXSize,nBlockYSize , GDT_Int16, 0,0);
> Thanks.
> On Mon, Sep 13, 2010 at 4:40 PM, Chaitanya kumar CH
> <chaitanya.ch at gmail.com> wrote:
>> Akhil,
>> Check which of the GDALRasterIO() calls are made.
>> Also, I noticed that you are calling GDALRasterIO() to read the data pixel
>> by pixel. Line by line will be faster, especially if the data is line
>> interleaved.
>> On Mon, Sep 13, 2010 at 8:30 PM, Akhil Jaggarwal <axj4159 at cs.rit.edu> wrote:
>>> Hi,
>>> I've shortened my questions to exactly this part of the code:
>>>  // read datasets, compare data and write
>>>                       if ( (pafScanline2[j] > 6 || pafScanline3[j] > 950)
>>>                                       pafScanline[j] == 2) {
>>>                                               change1, i, j, GDT_Byte,
>>> 0,0);
>>>                       else if( (pafScanline4[j] < -700) &&
>>>                                       pafScanline[j] == 6 ) {
>>>                                               change2, i, j, GDT_Byte,
>>> 0,0);
>>>                       else if( (pafScanline2[j] > 6) && pafScanline[j] ==
>>> 3 ) {
>>> 0,0);
>>>                       else if((pafScanline3[j]>1500) && pafScanline[j] ==
>>> 6) {
>>> 0,0);
>>>                       else
>>>                                               &pafScanline[j], i, j,
>>> GDT_Byte, 0,0);
>>>               //      printf("%u\n", pafScanline[j]);
>>> 1) Am I writing pixels the correct way?
>>> As of now I am getting just the exact copy of the input TIFF without
>>> any pixel modifications. Where step am I doing wrong.
>>> Any help would be great!
>>> Thanks.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
