[gdal-dev] compile error
Murat Beyhan beyhan at deprem.gov.tr
Thu Sep 16 14:34:08 EDT 2010
Dear Even,
Thanks for your reply.
I just remove php support from configure script than I achieved to
install gdal with mysql support.
Many Thanks for your help...
Murat
On Thu, 2010-09-16 at 19:39 +0200, Even Rouault wrote:
> Murat,
> unfortunately, no-one currently maintains the PHP bindings so there's a high
> risk they are not functionnal (PHP mainteners welcome by the way). See
> http://trac.osgeo.org/gdal/wiki/GdalOgrInPhp
> Actually I got the same errors as you. It appears the gdal_wrap.cpp in SVN is
> outdated. However I've managed to build the PHP bindings by doing this :
> cd swig/php
> make veryclean
> make build
> This assumes you have SWIG somewhere in your path (tested version here : swig
> 1.3.39)
> This produces a php_gdal.so, but again don't blame me if it doesn't work ;-)
> Even
> Le mercredi 15 septembre 2010 15:04:24, Murat Beyhan a écrit :
> > I tried to install gdal 1.7.2 on mandriva in order to read data from
> > mysql.
> > So I faced following error
> > Please help me How can I solve this problem
> > many thanks
> > Murat
> > g++ -I../../port -I../../gcore -I../../alg -I../../ogr `php-config
> > --includes` -fpic -c
> > gdal_wrap.cpp
> > gdal_wrap.cpp:562: warning: deprecated conversion from string constant
> > to
> > ‘char*’
> > gdal_wrap.cpp:867: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:867: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:867: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:867: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:867: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:868: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:868: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:868: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:868: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:868: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:869: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:869: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:870: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:870: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:870: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:870: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:870: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:882: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:882: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:882: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:882: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:882: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:883: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:883: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:883: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:883: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:883: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:884: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:884: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:885: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:885: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:885: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:885: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:885: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:915: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:915: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:915: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:915: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:915: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:916: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:916: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:916: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:916: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:916: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:917: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:917: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:918: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:918: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:918: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:918: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:918: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:1143: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:1143: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1143: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:1143: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:1143: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:1144: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:1144: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1144: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:1144: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:1144: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:1145: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:1145: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1146: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:1146: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1146: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:1146: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:1146: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:1261: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:1261: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1261: error: expected primary-expression before ‘*’
> > token
> > gdal_wrap.cpp:1261: error: ‘value’ was not declared in this
> > scope
> > gdal_wrap.cpp:1261: error: initializer expression list treated as
> > compound
> > expression
> > gdal_wrap.cpp:1262: error: ‘zend_property_reference’ was not declared in
> > this
> > scope
> > gdal_wrap.cpp:1262: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1262: error: expected primary-expression before ‘*’ token
> > gdal_wrap.cpp:1262: error: ‘value’ was not declared in this scope
> > gdal_wrap.cpp:1262: error: initializer expression list treated as
> > compound expression
> > gdal_wrap.cpp:1263: error: ‘zend_property_reference’ was not declared in
> > this scope
> > gdal_wrap.cpp:1263: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1264: error: ‘zend_property_reference’ was not declared in
> > this scope
> > gdal_wrap.cpp:1264: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1264: error: expected primary-expression before ‘*’ token
> > gdal_wrap.cpp:1264: error: ‘value’ was not declared in this scope
> > gdal_wrap.cpp:1264: error: initializer expression list treated as
> > compound expression
> > gdal_wrap.cpp:1276: error: ‘zend_property_reference’ was not declared in
> > this scope
> > gdal_wrap.cpp:1276: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1276: error: expected primary-expression before ‘*’ token
> > gdal_wrap.cpp:1276: error: ‘value’ was not declared in this scope
> > gdal_wrap.cpp:1276: error: initializer expression list treated as
> > compound expression
> > gdal_wrap.cpp:1277: error: ‘zend_property_reference’ was not declared in
> > this scope
> > gdal_wrap.cpp:1277: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1277: error: expected primary-expression before ‘*’ token
> > gdal_wrap.cpp:1277: error: ‘value’ was not declared in this scope
> > gdal_wrap.cpp:1277: error: initializer expression list treated as
> > compound expression
> > gdal_wrap.cpp:1278: error: ‘zend_property_reference’ was not declared in
> > this scope
> > gdal_wrap.cpp:1278: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1279: error: ‘zend_property_reference’ was not declared in
> > this scope
> > gdal_wrap.cpp:1279: error: ‘property_reference’ was not declared in this
> > scope
> > gdal_wrap.cpp:1279: error: expected primary-expression before ‘*’ token
> > gdal_wrap.cpp:1279: error: ‘value’ was not declared in this scope
> > gdal_wrap.cpp:1279: error: initializer expression list treated as
> > compound expression
> > gdal_wrap.cpp:1536: warning: deprecated conversion from string constant
> > to ‘char*’
> > gdal_wrap.cpp: In function ‘void _wrap_PushErrorHandler__SWIG_1(int,
> > zval*, zval**, zval*, int)’:
> > gdal_wrap.cpp:1806: warning: deprecated conversion from string constant
> > to ‘char*’
> > gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetDescription(int,
> > gdal_wrap.cpp:2128: warning: deprecated conversion from string constant
> > to ‘char*’
> > gdal_wrap.cpp: In function ‘void _wrap_MajorObject_SetDescription(int,
> > gdal_wrap.cpp:2160: warning: deprecated conversion from string constant
> > to ‘char*’
> > gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetMetadata_Dict(int,
> > gdal_wrap.cpp:2197: warning: deprecated conversion from string constant
> > to ‘char*’
> > gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetMetadata_List(int,
> > gdal_wrap.cpp:2252: warning: deprecated conversion from string constant
> > to ‘char*’
> > _wrap_MajorObject_SetMetadata__SWIG_0(int, zval*, zval**, zval*, int)’:
> > gdal_wrap.cpp:2306: warning: deprecated conversion from string constant
> > to ‘char*’
> > _wrap_MajorObject_SetMetadata__SWIG_1(int, zval*, zval**, zval*, int)’:
> > gdal_wrap.cpp:2372: warning: deprecated conversion from string constant
> > to ‘char*’
> > gdal_wrap.cpp: At global scope:
> > gdal_wrap.cpp:2463: error: redefinition of ‘pval
> > _wrap_propget_MajorObject’
> > gdal_wrap.cpp:869: error: ‘pval _wrap_propget_MajorObject’ previously
> > declared here
> > gdal_wrap.cpp:2463: error: ‘zend_property_reference’ was not declared in
> > this scope
> > gdal_wrap.cpp:2463: error: ‘property_reference’ was not declared in this
> > scope
> > make[2]: *** [gdal_wrap.o] Error 1
> > make[2]: Leaving directory `/usr/local/gdal-1.7.2/swig/php'
> > make[1]: *** [build] Error 2
> > make[1]: Leaving directory `/usr/local/gdal-1.7.2/swig'
> > make: *** [swig-modules] Error 2
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Afet ve Acil Durum Yönetimi Başkanlığı
Deprem Dairesi Başkanlığı
Eskişehir Yolu 12. Km.
Lodumlu/ANKARA
Tel: 312 2872680-1556
email:beyhan at deprem.gov.tr
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
