[gdal-dev] gdal_grid from contour
Frank Warmerdam
warmerdam at pobox.com
Fri Sep 17 09:12:38 EDT 2010
ahmet temiz wrote:
> thank you
> I am sorry but I am not clear.
> how shall we integrate elevation data if we burn vectors to all nodata ?
Ahmet,
You need to create a blank file for the study area - with all pixels set to
a nodata value. Then you burn the contours in with gdal_rasterize. The
pixels under the contours will be set to the elevation value of the contours.
Then interpolate with gdal_fillnodata.py.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
