[gdal-dev] gdal_translate distorts PROJCS specification ?
Frank Warmerdam
warmerdam at pobox.com
Fri Sep 17 10:44:57 EDT 2010
Sjur Kolberg wrote:
> Output of second GDALINFO, note the “-1.#INF” instead of 0 under the
> SPHEROID label.
> SPHEROID["Sphere",6367470,"-1.#INF"],
Sjur,
I believe this is a problem with sphere representation in the RST driver.
I see a similar problem if I do:
gdal_translate -of RST utm.tif \
-a_srs '+proj=utm +zone=11 +ellps=sphere' out.rst
Could you file a ticket on this issue?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
