[gdal-dev] how to prepare set up file......
Tamas Szekeres szekerest at gmail.com
Mon Sep 20 13:42:42 EDT 2010
If you install all the required dll-s and gdal support files along with your
executable, you might not require to install fwtools as a prerequisite.
Best regards,
Tamas
2010/9/20 mail2vajram <mail2vajram at gmail.com>
> i have used the gdal libraries through fwtools in my .NET application, and
> now i am giong to prepare the setup of my applaction. But in the code i set
> the environmental variable from fwtools path. That means should i have to
> install fwtools in the client system, if so please tell me the way to
> prepare one set up file which will install both fwtools and my application
> or is there any way.......
> Thank you...
> srinivas
> http://osgeo-org.1803224.n2.nabble.com/how-to-prepare-set-up-file-tp5549306p5549306.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100920/9ee96b03/attachment.html
