[gdal-dev] With Python bindings, should geometry objects created by ogr.Geometry() be explicitly destroyed?
Even Rouault even.rouault at mines-paris.org
Mon Sep 20 14:12:29 EDT 2010
Jason,
thanks for the effort ! I didn't find any obvious errors and it will likely be
very valuable to newcomers !
I just made a few changes in the way of expressing things. I guess some of the
unpleasant effects you can observe are more likely side effects of the
implementation and not really *design* decisions. That might be fixed/changed
in the future, but it will be weighted against backward compatibility.
The part where I'm not sure if about the Numpy ABI problems. I wasn't very
aware of problems related to it. From what I've seen in the code, it looks
like that the python bindings only use the C API/ABI of Numpy. But they indeed
access numpy structures (struct PyArrayObject namely), so if those structures
change between numpy versions, you're likely to have troubles. I don't believe
it is related to the fact that the GDAL python bindings are in C or C++ : the
swig generated files are indeed C++, but that's unrelated to the numpy ABI
issue, IMHO. However, I haven't changed anything in this section as I'm not
100% sure of my analysis.
Best regards,
Even
Le lundi 20 septembre 2010 18:29:26, Jason Roberts a écrit :
> Even,
> Thank you very much for your comments. Based on them, I started a new
> "Python Gotchas" page here http://trac.osgeo.org/gdal/wiki/PythonGotchas,
> referenced from http://trac.osgeo.org/gdal/wiki/GdalOgrInPython. Please
> review it to make sure I got everything right.
> Best regards,
> Jason
> -----Original Message-----
> From: Even Rouault [mailto:even.rouault at mines-paris.org]
> Sent: Saturday, September 18, 2010 5:52 AM
> To: gdal-dev at lists.osgeo.org
> Cc: Jason Roberts
> Subject: Re: [gdal-dev] With Python bindings, should geometry objects
> Jason,
> > I have some Python code that uses OGR geometry objects internally,
> > creating them like this:
> > point = ogr.Geometry(ogr.wkbPoint)
> > Does this code need to explicitly destroy these geometries, like the
> > following, to avoid leaks, or can it simply allow them to go out of scope
> > and have Python's reference counting and garbage collector clean them up?
> > point.Destroy()
> There's no reason to call Destroy(), at all. Native object gets destroyed
> when Python object goes out of scope, or when they are assigned to None.
> So replace foo.Destroy() by foo = None if you really want to control when
> the underlying C++ object is destroyed. This is indeed generally only
> interesting for I/O objects, like a GDALDataset or OGRDataSource, when you
> want to control when the file handle is closed.
> ds = gdal.GetDriverByName('GTiff').Create('foo.tif', 10, 10, 1)
> ds.GetRasterBand(1).Fill(255)
> ds = None # Now, foo.tif is closed and I can safely copy it
> shutil.copy('foo.tif', 'other.tif')
> > Does the situation change if I call feature.SetGeometry(point)? What
> > about feature.SetGeometryDirectly(point)?
> No, you don't need to call Destroy() either. SetGeometryDirectly() brings a
> bit of subtelty though : it makes the (C++) feature object the owner of the
> (C++) geometry object (whereas SetGeometry() just clones the passed
> geometry). The consequence for Python side is then when feature goes out
> of scope, C++ feature object dies and the C++ geometry object too, so the
> Python point object just referes to a dead C++ object.
> So do *NOT* do that :
> feature = ogr.Feature(layer_defn)
> feature = None # point becomes implicitely invalid at that point
> print point.ExportToWkt() # here you die
> The issue is that the bindings here expose something that is probably
> manageable for C++ programmers used to take into account object lifetime,
> but in Python, this can have surprising effect...
> > I'm sorry for my ignorance here. I found a nice GDAL tutorial that seems
> > to say they *should* be explicitly destroyed in certain circumstances
> > (see
> > http://www.gis.usu.edu/~chrisg/python/2009/lectures/ospy_slides2.pdf,
> > page 12). But I have not really seen any other examples of this.
> Destroy() was perhaps necessary with old-gen bindings, but I'm not even
> sure of that... Perhaps this shouldn't have been exposed at all... But, as
> mentionned in the slides, it is true that there are situations where you
> shouldn't call Destroy() at all.
> Do *NOT* do this :
> feat = lyr.GetNextFeature()
> geom = feat.GetGeometryRef()
> geom.Destroy() # Arg! C++ feature still points at the underlying C++
> geometry, but is is now dead
> feat = None # this will destroy the C++ feature, that will try to destroy
> the C++ geometry, but this one is already destroyed --> segfault !
> > If you follow gdal-dev, you probably notice that the "to destroy or not
> > to destroy" question comes up periodically from Python programmers, as
> > does the problem where someone gets a GDALDataset, gets a band, allows
> > the GDALDataset to go out of scope, and then expects the band to still
> > work. These are areas where the GDAL Python bindings to not work like
> > other Python libraries, causing confusion among Python programmers, who
> > generally expect reference counting that "just works" and that they only
> > need to explicitly close something when some kind of I/O is involved.
> Agreed.
> I wouldn't say that is a problem of reference counting, but more a problem
> of ownership and lifetime of C++ objects, that are sometimes destroyed
> when a Python object get out of scope, but shouldn't since another Python
> object indirectly still need them to be alive.
> Do *NOT* do this :
> feat = None # This kills the C++ feature, and its C++ geometry
> print(geom.ExportToWkt()) # segfault here. The C++ geometry no longer exist
> Byt you could do (and this is what the patch in ticket 3592 I mention below
> does under the hood):
> geom.please_keep_alive_object_after_equal_sign = feat
> feat = None # The underlying C++ object is still alive, since geom keeps
> the python feature object alive
> Similarly, do *NOT* do this :
> ds = gdal.Open('foo.tif')
> band = ds.GetRasterBand(1)
> ds = None
> print(band.Checksum())
> But you could do :
> band.please_keep_alive_object_after_equal_sign = ds
> ds = None
> Do *NOT* do this also :
> print(gdal.Open('foo.tif').GetRasterBand(1).Checksum())
> > It would be really great if there was FAQ that pointed out all of the
> > ways that GDAL differs from typical Python libraries. The scenarios I
> > mention above seem to be two of the most common ones. Would someone be
> > willing to create it? I would but do not feel competent enough at this
> > point.
> If you start a wiki page collecting all the info you found in the mailing
> list threads, that would be a beginning...
> Obviously, instead of documenting weird behaviour a better approach would
> be to fix the code so it behaves as expected...
> There was an attempt I pursued in http://trac.osgeo.org/gdal/ticket/3592 ,
> that would solve all the crashes in the above examples, but as you can see
> in the ticket, it raises backward compatibility issues in some cases
> (including the GDAL/OGR python autotest suite)... So the question is a bit
> like : should we inflict pain to existing users (in a few scenarios) to
> make the life of new users easier... ?
> But the patch doesn't solve all cases. Unfortunately, there would be still
> ways of causing segfault from Python. You can break some subtle API
> contracts, like adding a new field to a layer when features deriving from
> this layer definition are still active. And it isn't obvious how we could
> detect such situations to prevent them from happening (see
> http://trac.osgeo.org/gdal/ticket/3552 )
> Do *NOT* do that :
> feature = lyr.GetNextFeature()
> field_defn = ogr.FieldDefn("foo", ogr.OFTString)
> lyr.CreateField(field_defn) # now, existing features deriving from this
> layer are invalid
> feature.DumpReadable() # segfault
> > Thanks,
> > Jason
