[gdal-dev] OGR MS SQL Spatial driver has been added
David Lowther
dlowther at coordinatesolutions.com
Mon Sep 20 19:37:03 EDT 2010
Tamas,
I altered the table and that did indeed fix up my ogrinfo results. I'm still
not getting anything from Mapserver, but I am preparing a basic mapfile that
should make testing easier.
David Lowther
Coordinate Solutions, Inc.
_____
From: Tamas Szekeres [mailto:szekerest at gmail.com]
Sent: Monday, September 20, 2010 6:06 PM
To: David Lowther
Cc: gdal-dev
Subject: Re: [gdal-dev] OGR MS SQL Spatial driver has been added
David,
The driver assumes that the first field is the fid and the second is the
geometry column in the table. This doesn't appear to be a problem until the
table has been created by the same driver.
However in your case the field ordering doesn't follow this pattern. For a
workaround you may modify your table as follows:
select [PKey], [Feature], [SpatialDataKey], [StartX], [StartY] into
MetesAndBoundsHeader2 from MetesAndBoundsHeader
ALTER TABLE dbo.MetesAndBoundsHeader2 ADD CONSTRAINT
PK_MetesAndBoundsHeader2 PRIMARY KEY CLUSTERED (PKey)
and then do the same test with MetesAndBoundsHeader2. (Hopefully this will
solve the mapserver issue as well)
I consider this to be a bug in the driver and I'll correct this issue
tomorrow so as to allow the columns defined in arbitrary field order.
Best regards,
Tamas
2010/9/20 David Lowther <dlowther at coordinatesolutions.com>
CREATE TABLE [dbo].[MetesAndBoundsHeader](
[PKey] [int] IDENTITY(1,1) NOT NULL,
[SpatialDataKey] [int] NULL,
[StartX] [decimal](18, 4) NULL,
[StartY] [decimal](18, 4) NULL,
[Feature] [geometry] NULL,
CONSTRAINT [PK_MetesAndBoundsDescription] PRIMARY KEY CLUSTERED
[PKey] ASC
)WITH (PAD_INDEX = OFF, STATISTICS_NORECOMPUTE = OFF, IGNORE_DUP_KEY =
OFF, ALLOW_ROW_LOCKS = ON, ALLOW_PAGE_LOCKS = ON) ON [PRIMARY]
) ON [PRIMARY]
GO
SET IDENTITY_INSERT [dbo].[MetesAndBoundsHeader] ON
INSERT [dbo].[MetesAndBoundsHeader] ([PKey], [SpatialDataKey], [StartX],
[StartY], [Feature]) VALUES (8, 7, CAST(463644.9082 AS Decimal(18, 4)),
CAST(1484517.3764 AS Decimal(18, 4)),
0xE60E00000104050000009A999999734C1C4100000000E5A636419A999999734C1C41000000
00F5CD36419A99999939B01B4100000000A4CE36419A99999939B01B410000000094A736419A
999999734C1C4100000000E5A6364101000000020000000001000000FFFFFFFF0000000003)
[StartY], [Feature]) VALUES (9, 8, CAST(416571.3699 AS Decimal(18, 4)),
CAST(1465354.3699 AS Decimal(18, 4)),
0xE60E00000104050000009A999999ED6C1941000000000A5C36419A999999ED6C1941000000
001A8336419A999999B3D0184100000000C98336419A999999B3D0184100000000B95C36419A
999999ED6C1941000000000A5C364101000000020000000001000000FFFFFFFF0000000003)
SET IDENTITY_INSERT [dbo].[MetesAndBoundsHeader] OFF
David Lowther
_____
Sent: Monday, September 20, 2010 4:56 PM
To: David Lowther
Cc: gdal-dev
It seems almost as if there is an index off in the field information.
David,
That's strange indeed. What is the database type of this field in the table?
Could you provide your test data to reproduce this?
I am also not seeing any features when I render the layer in Mapserver
(though that could be any number of things as I am just getting started with
OGR MSSQL in Mapserver).
It would be helpful to see your mapfile to make sure about the problem.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100920/02285dfa/attachment-0001.html
