Re: [gdal-dev] svn build on mac osx 10.6.4 (errors in GDALmake.opt)
Ivan Lucena
ivan.lucena at pmldnet.com
Wed Sep 22 07:05:40 EDT 2010
Massimo,
if you just run "/.configure" it should show:
checking for python bindings... disabled
SWIG Bindings: no
Then you can just run make and it should be fine. Even if you want to use
GDAL+Python.
Did you install any additional Python distribution on top of what comes
with your Mac?
Send the result of those commands:
% python --version
% printenv | grep python
% whereis python
Regards,
Ivan
-------Original Message-------
To: gdal-dev
Subject: [gdal-dev] svn build on mac osx 10.6.4 (errors in GDALmake.opt)
Sent: Sep 22 '10 02:07
Hi ,
any clue about this message :
"GDALmake.opt:50: *** missing separator. Stop. "
i have it tring to run "make "
on mac osx 10.6.4
1
2
3
4
5
6
7
8
9
10
11
12
PYTHON_INCLUDES = @PYTHON_INCLUDES@
PYTHON_LIBS = @PYTHON_LIBS@
PYTHON_CFLAGS = @PYTHON_CFLAGS@ @NUMPY_FLAG@
PYTHON = python
PYTHON_DEV = @PYTHON_DEV@
PY_LD_SHARED = @PY_LD_SHARED@
PY_SO_EXT = @PY_SO_EXT@
PY_HAVE_SETUPTOOLS=Leopard libedit detected.
1
# Next Generation SWIG bindings
BINDINGS = python
(line:9 = line:50 in GDALmake )
i used a "standard "
./configure,
on gdal svn-trunk
gdal-dev mailing list
[LINK: http://mbox.pmldnet.com/compose.php?to=gdal-dev@lists.osgeo.org]
gdal-dev at lists.osgeo.org
[LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100922/5f5b6380/attachment.html
