[gdal-dev] legend of the dem ?
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Sep 23 11:22:05 EDT 2010
ahmet,
Perhaps the python script rgb2pct.py can help you. ( Refer to
http://www.gdal.org/rgb2pct.html & http://www.gdal.org/gdal_utilities.html )
PS: You can easily set some fancy color tables using some desktop GIS
applications.
On Thu, Sep 23, 2010 at 5:48 PM, ahmet temiz <ahmettemiz88 at gmail.com> wrote:
> I learnt later. This color file should be created by myself.
> I had asked if there was any automatic way of generation of that file
> as in "GMT makecpt"
> regards
> 2010/9/23 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> > ahmet,
> > The gdaldem color-relief utility uses the color entries from a text file
> > which is given as the argument color_text_file. If you did create a map
> > using gdaldem color-relief, you should already have the file. Use the
> > entries from it.
> > On Wed, Sep 22, 2010 at 1:12 AM, ahmet temiz <ahmettemiz88 at gmail.com>
> wrote:
> >> So, what are they ?
> >> 2010/9/21 Chaitanya kumar CH <chaitanya.ch at gmail.com>:
> >> > ahmet,
> >> > You have to create a legend of the dem from the color configuration
> file
> >> > using some other tool.
> >> > On Wed, Sep 22, 2010 at 12:32 AM, ahmet temiz <ahmettemiz88 at gmail.com
> >> > wrote:
> >> >> I used gdaldem color-relief and created the map.
> >> >> Now, how can I generate the legend of the dem ?
> >> >> kind regards
> >> >> _______________________________________________
> >> >> gdal-dev mailing list
> >> >> gdal-dev at lists.osgeo.org
> >> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> >> > Best regards,
> >> > Chaitanya kumar CH.
> >> > /tʃaɪθənjə/ /kʊmɑr/
> >> > +91-9494447584
> >> > 17.2416N 80.1426E
> > Best regards,
> > Chaitanya kumar CH.
> > /tʃaɪθənjə/ /kʊmɑr/
> > +91-9494447584
> > 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100923/4e42ae9b/attachment.html
