[gdal-dev] OGDI 3.2 Beta 2
Jeshua Lacock jeshua at OpenOSX.com
Thu Sep 23 21:04:03 EDT 2010
Greetings,
Is gdal 1.7.2 supposed to be compatible with OGDI 3.2 beta 2?
I am getting the following (I tried making a symbolic link from my libogdi.dylib to libogdi31.dylib:
configure:18511: result: no
configure:18530: checking for cln_GetLayerCapabilities in -logdi31
configure:18555: gcc -o conftest -arch x86_64 -arch x86_64 -L/usr/local/lib -arch x86_64 conftest.c -logdi31 -L/usr/local -L/usr/local/lib -logdi31 -L/usr/local -L/usr/local/lib -lnetcdf -L/usr/local/grass-6.4.0/lib -lgrass_vect -lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient -lgrass_dbmibase -lgrass_I -lgrass_gproj -lgrass_vask -lgrass_gmath -lgrass_gis -lgrass_datetime -lpq -L/usr/local/pgsql/lib -lpq -lz -L/usr -L/usr/lib -lpthread -ldl  >&5
ld: library not found for -logdi31
collect2: ld returned 1 exit status
configure:18555: $? = 1
configure: failed program was:
| /* confdefs.h */
| #define PACKAGE_NAME ""
| #define PACKAGE_TARNAME ""
| #define PACKAGE_VERSION ""
| #define PACKAGE_STRING ""
| #define PACKAGE_BUGREPORT ""
| #define PACKAGE_URL ""
| #define STDC_HEADERS 1
| #define HAVE_SYS_TYPES_H 1
| #define HAVE_SYS_STAT_H 1
| #define HAVE_STDLIB_H 1
| #define HAVE_STRING_H 1
| #define HAVE_MEMORY_H 1
| #define HAVE_STRINGS_H 1
| #define HAVE_INTTYPES_H 1
| #define HAVE_STDINT_H 1
| #define HAVE_UNISTD_H 1
| #define HAVE_DLFCN_H 1
| #define LT_OBJDIR ".libs/"
| #define HAVE_LIBDL 1
| #define HAVE_ASSERT_H 1
| #define HAVE_FCNTL_H 1
| #define HAVE_LIMITS_H 1
| #define HAVE_LOCALE_H 1
| #define HAVE_FLOAT_H 1
| #define HAVE_ERRNO_H 1
| #define HAVE_LONG_LONG 1
| #define UNIX_STDIO_64 1
| #define VSI_LARGE_API_SUPPORTED 1
| #define VSI_FTELL64 ftello
| #define VSI_FSEEK64 fseeko
| #define VSI_STAT64 stat64
| #define VSI_STAT64_T stat64
| #define VSI_FOPEN64 fopen
| #define SIZEOF_INT 4
| #define SIZEOF_UNSIGNED_LONG 8
| #define SIZEOF_VOIDP 8
| #define HAVE_IEEEFP 1
| #define HOST_FILLORDER FILLORDER_LSB2MSB
| #define HAVE_VPRINTF 1
| #define HAVE_SNPRINTF 1
| #define HAVE_VSNPRINTF 1
| #define HAVE_ATOLL 1
| #define HAVE_STRTOF 1
| #define HAVE_GETCWD 1
| #define HAVE_DECL_STRTOF 1
| #define HAVE_GCC_ATOMIC_BUILTINS 1
| #define HAVE_PTHREAD_MUTEX_RECURSIVE 1
| #define CPL_MULTIPROC_PTHREAD 1
| #define HAVE_LIBPQ 1
| /* end confdefs.h.  */
| /* Override any GCC internal prototype to avoid an error.
|    Use char because int might match the return type of a GCC
|    builtin and then its argument prototype would still apply.  */
| #ifdef __cplusplus
| extern "C"
| #endif
| char cln_GetLayerCapabilities ();
| int
| main ()
| return cln_GetLayerCapabilities ();
|   return 0;
configure:18564: result: no
configure:18583: error: libogdi not found.
Thanks,
Jeshua Lacock, Owner
<http://OpenOSX.com>
phone: 208.462.4171
