[gdal-dev] tiff with colortable loses alpha values?
Even Rouault
even.rouault at mines-paris.org
Tue Sep 28 13:29:24 EDT 2010
Vincent,
The TIFF format doesn't allow storing the alpha component, so it is ignored.
See the TIFF specification, section 5 :
http://partners.adobe.com/public/developer/en/tiff/TIFF6.pdf
Possible workarounds :
* work with RGBA tiff
* add a mask band
Best regards,
Even
Le mardi 28 septembre 2010 16:24:18, Vincent Schut a écrit :
> Hi,
> I'm creating a geotiff with colortable using the python bindings,
> however, the alpha value of the colorentry is lost / always set to 255
> (says gdalinfo on the output image).
> Does gdal/geotiff with colortable not support rbga?
> Or, what am I doing wrong?
> Testcase is below:
> from osgeo import gdal
> gtiff = gdal.GetDriverByName('GTiff')
> ds = gtiff.Create('/home/vincent/test.tif', 1, 1, 1, gdal.GDT_Byte)
> ct = gdal.ColorTable()
> ct.SetColorEntry(1, (100, 100, 100, 100))
> ds.GetRasterBand(1).SetColorTable(ct)
> gdalinfo on /home/vincent/test.tif says 100,100,100,255 for colorentry 1...
> using gdal from svn, internal geotiff.
> Regards,
> Vincent.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
