[gdal-dev] Erdas 2010 and OpenEV different views
ibrahim saricicek
ibrahimsaricicek at gmail.com
Wed Sep 29 02:59:38 EDT 2010
Dear List,
>From OpenEv, Exporting with "Advanced Options/Scale to View Settings" works
now.
Thanks a lot...
Regards..
On Tue, Sep 28, 2010 at 4:49 PM, Chaitanya kumar CH
<chaitanya.ch at gmail.com>wrote:
> Ibrahim,
> I don't think you can save the image that way in openev.
> You can use gdal_translate to perform linear scaling.
> Use the -scale option. If you think you can stand to lose some info in very
> dark or very bright areas, specify appropriate values for src_min and
> src_max.
> http://www.gdal.org/gdal_translate.html
> On Tue, Sep 28, 2010 at 6:26 PM, ibrahim saricicek <
> ibrahimsaricicek at gmail.com> wrote:
>> Hi List,
>> Thanks "Linear Stretch/ Enhancement" works.
>> And one more question how can i save the image with "Linear Stretch/
>> Enhancement" applied?
>> Regards..
>> On Tue, Sep 28, 2010 at 2:59 PM, Chaitanya kumar CH <chaitanya.ch@
>> gmail.com> wrote:
>>> Ibrahim,
>>> Try the buttons in openev toolbar with the slant lines. They perform
>>> different kinds of rescaling.
>>> On Tue, Sep 28, 2010 at 5:10 PM, Ibrahim Saricicek <
>>>> Hi List,
>>>> By Erdas Imagine 2010 I've combined 3 bands (by Spectral/Layer Stack
>>>> Menu).
>>>> Saved as 32 bit. And by "Rescale" menu, rescaled to 8 bit.
>>>> The image is shown the same on Mapserver, QGis, Ossim, OpenEv and
>>>> different
>>>> on Erdas Imagine 2010.
>>>> You may see the differences on the images. And I attached the image on
>>>> tif
>>>> format.
>>>> What is wrong with QGis, Ossim or OpenEv?
>>>> Thanks in advance...
>>>> http://osgeo-org.1803224.n2.nabble.com/file/n5579024/erdas.jpg
>>>> http://osgeo-org.1803224.n2.nabble.com/file/n5579024/chip.tif chip.tif
>>>> http://osgeo-org.1803224.n2.nabble.com/file/n5579024/gdal.jpg
>>>> View this message in context:
>>>> http://osgeo-org.1803224.n2.nabble.com/Erdas-2010-and-OpenEV-different-views-tp5579024p5579024.html
>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> Best regards,
>>> Chaitanya kumar CH.
>>> /tʃaɪθənjə/ /kʊmɑr/
>>> +91-9494447584
>>> 17.2416N 80.1426E
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100929/9b254866/attachment-0001.html
