[gdal-dev] kml superoverlay help request
brian
rush at winkey.org
Mon Apr 4 12:23:16 EDT 2011
Brian
IIRC the superoverlay driver is read only.
Reading images from knls are problematic at best.
Can you give me some info on the stucture of the kmz's?
Brian
On Sun, 2011-04-03 at 22:43 -0700, Brian Wilson wrote:
> I received a batch of files that are in a kml format that looks like
> the "KML SUPEROVERLAY" that gdal supports.
> There is a kmz flle which when unzipped contains a batch of JPEGs and
> a file called doc.kml that describes them.
> My "gdalinfo --formats" command says "KMLSUPEROVERLAY (rwv): Kml Super
> Overlay" but I don't know how to feed it the files.
> I tried the KMZ, the unpacked directory, and the doc file
> ERROR 4: `nc4806-50.kmz' not recognised as a supported file format.
> ERROR 4: `nc4806-50' not recognised as a supported file format.
> ERROR 4: `nc4806-50/doc.kml' not recognised as a supported file
> format.
> Or maybe I am wrong about what a kml super overlay is?
> My google searches only turned up help with writing the kml files, but
> I am assuming the formats "rwv" means it can read, write, and also do
> something else starting with the letter 'v' -- always wondered about
> those codes like rw+ maybe the + means update or append?? (And "rov"
> means remotely operated vehicle? oops context shift sorry)
> Thanks in advance
> Brian Wilson
> Corvallis OR
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
