[gdal-dev] Libgdal Compilation with MinGW
Rodolfo Bonnin rodolfobonnin at suremptec.com.ar
Wed Apr 6 11:02:02 EDT 2011
Hello all,
I am trying to compile gdal using CMake with MinGW 4.4, and had the
following errors:
______________________________
[...]libkml-1.2.0/src/kml/base/file_win32.cc:3
5:19: error: xstring: No such file or directory
[...]libkml-1.2.0/src/kml/base/file_win32.cc:4
3:35: error: empty character constant
So I changed the file_win32 , obtaining the following diff:
____________________________________
--- src/kml/base/file_win32.cc     Wed Jan 13 21:16:30 2010
+++ src/kml/base/file_win32.cc   Wed Apr  6 10:50:27 2011
@@ -32,7 +32,6 @@
 #include "kml/base/file.h"
 #include <windows.h>
 #include <tchar.h>
-#include <xstring>
 #include <algorithm>
 namespace kmlbase {
@@ -40,7 +39,7 @@
 // Internal to the win32 file class. We need a conversion from string to
 // LPCWSTR.
 static std::wstring Str2Wstr(const string& str) {
-  std::wstring wstr(str.length(), L'');
+  std::wstring wstr(str.length(), L' ');
  std::copy(str.begin(), str.end(), wstr.begin());
  return wstr;
_________________________________________________
After that the library compiled OK.
This was a quick fix, and I have to check it for correctness, any
comments are welcome regarding a better way to fix the compilation
(Conditional code to check for MinGW before including xstring for
example)
Regards and thanks in advance.
Ing. Rodolfo Bonnin
SUR Emprendimientos Tecnológicos
Perú 345  Piso 5to Oficina "B" (C1067AAG)
Ciudad de Buenos Aires, Argentina
Tel. +54 (11) 4342-2976/84
www.suremptec.com
Ing. Rodolfo Bonnin
www.suremptec.com
