[gdal-dev] Catch a GDALOpen exception
Mateusz Loskot
mateusz at loskot.net
Wed Apr 6 16:15:12 EDT 2011
Even Rouault wrote:
> Mateusz Loskot wrote:
>> This is interesting. Could you give example?
>> How is checking if GDALOpen returned NULL and prematurely exiting
>> different to throwing exception?
> The ::Open() method of GDAL drivers is supposed to make all necessary
> cleanups, even in case of errors, before returning NULL.
> But if you install a custom CPL error handler that throws a C++ exception,
> and a CPLError() is emitted in GDAL driver code, it will directly
> unwind to the matching catch( xx ) { } in your code.
> Let's look at the Open() method of the BMP driver
> You have :
> if (poDS->nRasterXSize <= 0 || poDS->nRasterYSize <= 0)
> CPLError( CE_Failure, CPLE_AppDefined,
> "Invalid dimensions : %d x %d",
> poDS->nRasterXSize, poDS->nRasterYSize);
> delete poDS;
> return NULL;
Even,
Yes, you are right. I missed you mean the CPLError. In case of custom
throwing handler it will jump out of the context. I do throw exceptions
reacting on GDAL errors, but not from within GDAL internal context,
like the custom handler.
>> It should be possible to react on GDAL errors and throw exception
>> as long as certain cleanup is performed.
>> > (there's no guarantee that the GDAL error is emitted
>> > before the cleanup of ressources has been done).
>> What error emission you mean? Returning NULL? Call to abort()?
> An error emitted by CPLError().
Yes, that's what I was missing.
But, now this "before" should read "after", I think:
"no guarantee that the GDAL error is emitted after the cleanup of
ressources has been done", so leaks possible.
Best regards,
Mateusz Loskot
http://mateusz.loskot.net
