[gdal-dev] Can't read transformation coefficients from tiff
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Apr 7 07:22:17 EDT 2011
Chris,
GDAL is using the GCPs for location information.
On Thu, Apr 7, 2011 at 4:08 PM, Goo Creations <goocreations at gmail.com>wrote:
> Yes, here it is:
> Size is 8415, 1368
> Coordinate System is `'
> GCP Projection =
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433],
> AUTHORITY["EPSG","4326"]]
> GCP[ 0]: Id=1, Info=
> (1,1) -> (1.09027789320281,36.5294598527946,0)
> GCP[ 1]: Id=2, Info=
> (8415,1) -> (1.69376245781042,36.497946615707,0)
> GCP[ 2]: Id=3, Info=
> (8415,1368) -> (1.68268551099186,36.5851791048298,0)
> GCP[ 3]: Id=4, Info=
> (1,1368) -> (1.06532262333098,36.6082043228718,0)
> Metadata:
> TIFFTAG_DATETIME=2010:10:05 06:46:58
> AREA_OR_POINT=Point
> Image Structure Metadata:
> INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 1368.0)
> Upper Right ( 8415.0, 0.0)
> Lower Right ( 8415.0, 1368.0)
> Center ( 4207.5, 684.0)
> Band 1 Block=8415x128 Type=UInt16, ColorInterp=Gray
> On Thu, Apr 7, 2011 at 11:51 AM, Chaitanya kumar CH <chaitanya.ch@
> gmail.com> wrote:
>> Chris,
>> Can you provide the gdalinfo output of the geotiff?
>> On Thu, Apr 7, 2011 at 2:29 PM, Goo Creations <goocreations at gmail.com>wrote:
>>> I've worked through some QGis code and noticed that if this happens,
>>> GDALAutoCreateWarpedVRT is called on the image to create a copy. So
>>> GDALAutoCreateWarpedVRT somehow retrieves some sort of metadata to
>>> accomplish this.
>>> On Thu, Apr 7, 2011 at 10:44 AM, Goo Creations <goocreations at gmail.com>wrote:
>>>> A couple of different apps, such as QGis and Monteverdi (who rotated the
>>>> image). If I view the image in a normal image viewer (or application not
>>>> built on top of GDAL, the image is not rotated). Hence there must be some
>>>> metadata from GDAL these applications use to rotate the image.
>>>> And yes, I can read other metadata.
>>>> Chris
>>>> On Thu, Apr 7, 2011 at 10:34 AM, Chaitanya kumar CH <chaitanya.ch@
>>>> gmail.com> wrote:
>>>>> Chris,
>>>>> What did you use to view the image? Were you able to read any other Geo
>>>>> related data with that?
>>>>> On Thu, Apr 7, 2011 at 1:56 PM, Goo Creations <goocreations at gmail.com>wrote:
>>>>>> Hi all
>>>>>> I tried to read the transformation coefficients by using
>>>>>> GDALDataset::GetGeoTransform. This function however returned CE_Failure, so
>>>>>> i assume that the values are not stored in the metadat.
>>>>>> When I view the image, the image is rotated. There is no world file or
>>>>>> anything that could cause the rotation.
>>>>>> So my question: If these values are not stored in the metadata, how
>>>>>> does GDAL handle the rotation, pixel size, etc?
>>>>>> Chris
>>>>>> _______________________________________________
>>>>>> gdal-dev mailing list
>>>>>> gdal-dev at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>>>>> Best regards,
>>>>> Chaitanya kumar CH.
>>>>> /tʃaɪθənjə/ /kʊmɑr/
>>>>> +91-9494447584
>>>>> 17.2416N 80.1426E
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110407/78efa4ac/attachment.html
