[gdal-dev] Wrong parameter value for EPSG:3168 and EPSG:3375 (RSO)
Hilmy Hashim
hilmyh at gmail.com
Fri Apr 8 09:12:04 EDT 2011
Hi list,
I assigned geotiff raster an srs using gdal_translate with the EPSG number
as follows:
gdal_translate -a_srs EPSG:3168 sourcefile destinationfile
Using gdalinfo, I notice that the false_easting parameter is 0 where it
should be 804670.24
Coordinate System is:
PROJCS["Kertau (RSO) / RSO Malaya (m)",
GEOGCS["Kertau (RSO)",
DATUM["Kertau_RSO",
SPHEROID["Everest 1830 (RSO
1969)",6377295.664,300.8017000000015,
AUTHORITY["EPSG","7056"]],
AUTHORITY["EPSG","6751"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4751"]],
PROJECTION["Hotine_Oblique_Mercator"],
PARAMETER["latitude_of_center",4],
PARAMETER["longitude_of_center",102.25],
PARAMETER["azimuth",323.0257905],
PARAMETER["rectified_grid_angle",323.1301023611111],
PARAMETER["scale_factor",0.99984],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AUTHORITY["EPSG","3168"]]
I am using OSGeo4W on Windows 7 64 bit (Gdal 1.4.5.0) shell. It is the same
with gdal 1.6, 1.7, gdal-dev, gdal 1.7.2 on Ubuntu 10.04 and QGis 1.7 (gdal
1.8).
I checked the OSGeo4W\share\proj\epsg file, but the values there are
correct. The anomaly also affects EPSG:3375 which uses the same projection.
QGis or Geoserver doesn't have a problem displaying the raster with the
assigned srs, so it looks like its just a problem with gdalinfo.
regards
*Hilmy*
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110408/f81bedde/attachment-0001.html
