[gdal-dev] Wrong parameter value for EPSG:3168 and EPSG:3375 (RSO)
Hilmy Hashim
hilmyh at gmail.com
Sat Apr 9 06:01:49 EDT 2011
Thanks very much Even. Good to know where the error is.
*Hilmy*
On Sat, Apr 9, 2011 at 4:50 PM, Even Rouault
<even.rouault at mines-paris.org>wrote:
> Selon Hilmy Hashim <hilmyh at gmail.com>:
> I can confirm the bug. It is in fact a bug in libgeotiff. I have reported
> it as
> http://trac.osgeo.org/geotiff/ticket/38 with an attached patch to fix it.
> > Hi list,
> > I assigned geotiff raster an srs using gdal_translate with the EPSG
> number
> > as follows:
> > gdal_translate -a_srs EPSG:3168 sourcefile destinationfile
> > Using gdalinfo, I notice that the false_easting parameter is 0 where it
> > should be 804670.24
> > Coordinate System is:
> > PROJCS["Kertau (RSO) / RSO Malaya (m)",
> > GEOGCS["Kertau (RSO)",
> > DATUM["Kertau_RSO",
> > SPHEROID["Everest 1830 (RSO
> > 1969)",6377295.664,300.8017000000015,
> > AUTHORITY["EPSG","7056"]],
> > AUTHORITY["EPSG","6751"]],
> > PRIMEM["Greenwich",0],
> > UNIT["degree",0.0174532925199433],
> > AUTHORITY["EPSG","4751"]],
> > PROJECTION["Hotine_Oblique_Mercator"],
> > PARAMETER["latitude_of_center",4],
> > PARAMETER["longitude_of_center",102.25],
> > PARAMETER["azimuth",323.0257905],
> > PARAMETER["rectified_grid_angle",323.1301023611111],
> > PARAMETER["scale_factor",0.99984],
> > PARAMETER["false_easting",0],
> > PARAMETER["false_northing",0],
> > UNIT["metre",1,
> > AUTHORITY["EPSG","9001"]],
> > AUTHORITY["EPSG","3168"]]
> > I am using OSGeo4W on Windows 7 64 bit (Gdal 1.4.5.0) shell. It is the
> same
> > with gdal 1.6, 1.7, gdal-dev, gdal 1.7.2 on Ubuntu 10.04 and QGis 1.7
> (gdal
> > 1.8).
> > I checked the OSGeo4W\share\proj\epsg file, but the values there are
> > correct. The anomaly also affects EPSG:3375 which uses the same
> projection.
> > QGis or Geoserver doesn't have a problem displaying the raster with the
> > assigned srs, so it looks like its just a problem with gdalinfo.
> > regards
> > *Hilmy*
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110409/8dc2fd08/attachment.html
