[gdal-dev] gdal_translation interpolation
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Apr 11 03:57:18 EDT 2011
Yang,
gdalwarp provides a much better control over the interpolation of the data.
http://www.gdal.org/gdalwarp.html
On Mon, Apr 11, 2011 at 12:10 PM, kui yang <yang3kui at gmail.com> wrote:
> hi,
> What's  the interpolation method used in gdal_translate
> when the size of the input dataset is changed with the
> -outsize flag?
> Are there different interpolation methods that can be used?
> If yes, what are they and the flags to use?
> Thanks in advance.
> yang
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110411/ec08c0e7/attachment.html
