[gdal-dev] rotate raster cells
    Chaitanya kumar CH
    chaitanya.ch at gmail.com
    Mon Apr 11 09:42:33 EDT 2011
Matthew,
I did not understand exactly what you need but you may be able to use the
affine transformation coordinates. They can be adjusted for displacement and
rotation of the raster.
See the documentation for GDALDataset::GetGeoTransform()
On Mon, Apr 11, 2011 at 4:50 PM, Matthew Snape <SnapeM at rpsgroup.com> wrote:
>  I have a raster that I wish to rotate.  I would like to retain the
> projection but create grid cells that are not aligned in the X and Y
> planes.  Is it possible to use GDAL to make such a translation, and do
> drivers have support for representing data in such a way?
> This e-mail message and any attached file is the property of the sender and
> is sent in confidence to the addressee only.
> Internet communications are not secure and RPS is not responsible for their
> abuse by third parties, any alteration or corruption in transmission or for
> any loss or damage caused by a virus or by any other means.
> RPS Planning and Development Limited, company number: 02947164 (England).
> Registered office: Centurion Court, 85 Milton Park Abingdon Oxfordshire OX14
> 4RY.
> RPS Group Plc web link: http://www.rpsgroup.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110411/0150c265/attachment.html
