[gdal-dev] Re: FileGDB OGR driver test
Matt Wilkie
matt.wilkie at gov.yk.ca
Tue Apr 12 14:40:58 EDT 2011
> ArcGIS 10 FileGDB's right ?
If the api allows for using gdb's from different versions then the test
suite should have different versions too. In any case I can make v10 gdb's.
> Current GDAL trunk builds against FileGDB API beta3 under Linux 32bit. Too bad
> ESRI doesn't provide any 64bit build of the FileGDB API (yet... ?)
We are working on a Linux 64-bit release of the File Geodatabase API. It
will not release with the 1.0 release of the API, but as a part of a
follow on release later this year.
Lance Shipman
Geodatabase Product Engineer, File Geodatabase
esri
http://forums.arcgis.com/threads/22223-Cross-plattform-API?p=89593&viewfull=1#post89593
-matt
