[gdal-dev] Re: FileGDB OGR driver test
Even Rouault even.rouault at mines-paris.org
Tue Apr 12 14:47:19 EDT 2011
Le mardi 12 avril 2011 20:37:06, Smith, Michael ERDC-CRREL-NH a écrit :
> Even,
> How do you configure gdal/ogr to build with the linux api?
This is a bit involved since there's no ./configure support yet, so I compile
it "at hand" as a plugin
Here's the line I use from GDAL root source directory :
g++ -Wall -g ogr/ogrsf_frmts/filegdb/*.c* -shared -o ogr_filegdb.so -Iport -
Igcore -Iogr -Iogr/ogrsf_frmts -Iogr/ogrsf_frmts/filegdb -L. -lgdal -
I/home/even/filegdb/dist/include -L/home/even/filegdb/dist/lib  -
I/home/even/filegdb/dist/src/FileGDBEngine/include/FileGDBLinux -lFileGDBAPI
You must change the /home/even/filegdb/ paths to where you uncompress the
filegdb API
And you must define the GDAL_DRIVER_PATH environmenet variable to point to the
path where ogr_filegdb.so is
> I'm working on getting some example datasets together.
> Mike
> > Le mardi 12 avril 2011 19:08:24, Hermann Peifer a écrit :
> >> On 04/04/2011 05:05, Ragi Burhum wrote:
> >>> Hello list,
> >>> I am trying to test a new version of the FileGDB driver for OGR, but I
> >>> lack enough FileGDBs to test :)
> >> Is the lack of FileGDBs still an issue? At work, we have several
> >> hundreds of them and I could check if I can make some available.
> > ArcGIS 10 FileGDB's right ?
> > Yes "real" data would be usefull. But it would also be usefull if you (or
> > anyone else) could provide small and freely redistribuable
> > samples (potentially "fake" data) with different types of
> > geometries (1 feature for each geometry type is enough in theory), column
> > types (integer, single, double, string, date), etc.. so that it can be
> > included in the GDAL/OGR autotest suite.
> >>> If you have an *ArcGIS 10* FileGDB and would like to test the FileGDB
> >>> driver (and report back), feel free to grab a gdal-trunk binary I made
> >>> for Windows.
> >> A related question: will there ever be a FileGDB driver for a
> >> non-Windows OS? Is this feasible at all?
> > Current GDAL trunk builds against FileGDB API beta3 under Linux 32bit.
> > Too bad ESRI doesn't provide any 64bit build of the FileGDB API (yet...
> >> Hermann
> >> _______________________________________________
> >> gdal-dev mailing list
> >> gdal-dev at lists.osgeo.org
> >> http://lists.osgeo.org/mailman/listinfo/gdal-dev
