[gdal-dev] Re: FileGDB OGR driver test
Smith, Michael ERDC-CRREL-NH michael.smith at usace.army.mil
Tue Apr 12 15:45:25 EDT 2011
I have a test v10 filegdb with points, lines, polygons (all with Z and M but
I think the measures aren't populated). There are also some non geometry
tables and some relationship classes.
Its available at
http://12.189.158.78:8081/downloads/test_fgdb.gdb.zip
Mike
Michael Smith
Remote Sensing/GIS Center
US Army Corps of Engineers
On 4/12/11 2:48 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> Le mardi 12 avril 2011 20:40:58, Matt Wilkie a écrit :
>>> ArcGIS 10 FileGDB's right ?
>> If the api allows for using gdb's from different versions then the test
>> suite should have different versions too. In any case I can make v10 gdb's.
> No, the FileGDB API only reads v10 gdb's.
>>> Current GDAL trunk builds against FileGDB API beta3 under Linux 32bit.
>>> Too bad ESRI doesn't provide any 64bit build of the FileGDB API (yet...
>> We are working on a Linux 64-bit release of the File Geodatabase API. It
>> will not release with the 1.0 release of the API, but as a part of a
>> follow on release later this year.
>> Lance Shipman
>> Geodatabase Product Engineer, File Geodatabase
>> esri
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
