[gdal-dev] GDAL Native Libraries 1.4.5b for Linux64 not available
Daniele Romagnoli
daniele.romagnoli at geo-solutions.it
Wed Apr 13 05:46:03 EDT 2011
Hi all,
the ImageIO-Ext 1.0.8 uses GDAL 1.4.5.
GDAL 1.7.3 is needed by ImageIO-Ext 1.1.x (which is not yet used by
GeoServer 2.2.x... I'm still working on this, these days)
About the broken link, I think there is some issue on the new site based on
Kenai. Not sure why/how it has been broken since these files have been
already downloaded several times. (It seems that several links now reports
"not found")
I have uploaded it again the file you are looking for. (I will check which
files are now unavailable and then redeploy them if needed)
Hope this helps.
Regards,
Daniele
On Wed, Apr 13, 2011 at 11:02 AM, Chaitanya kumar CH <chaitanya.ch at gmail.com
> wrote:
> The site also shows the GDAL 1.7.3 version in the dependencies and the file
> exists. Perhaps imageio-ext 1.0.8 does support gdal1.7.3
> On Wed, Apr 13, 2011 at 1:59 PM, Andreas Oxenstierna <ao at t-kartor.se>wrote:
>> If I am interpreting the information correctly on
>> http://docs.geoserver.org/latest/en/user/data/gdal.html
>> GeoServer is using Image I/O-Ext 1.0.8 which is using GDAL 1.4.5, that is
>> my reason.
>> How can I get access to the file gdal1.4.5b-linux64-base.tar.gz<http://java.net/projects/imageio-ext/downloads/directory/Releases/Dependencies/GDAL/NativeLibraries/1.4.5/Linux64/gdal1.4.5b-linux64-base.tar.gz>? I cannot download it from the link below with any tested browser, instead
>> getting a message "The page you were looking for doesn't exist".
>> Andreas
>> Andreas,
>> The file exists. However, the GDAL 1.4 branch is no longer supported. The
>> latest stable version is 1.8 although 1.7 is also supported. Why don't you
>> use the 1.7 version.
>> On Wed, Apr 13, 2011 at 1:16 PM, Andreas Oxenstierna <ao at t-kartor.se>wrote:
>>> Need to include GDAL support for GeoServer 2.1 on Linux 64-bit.
>>> However, it seems that the link to the native libraries on
>>> is broken. Can I get the gdal1.4.5b-linux64-base.tar.gz from somewhere else
>>> or do I need to build it from the source files?
>>> Andreas Oxenstierna
>>> T-Kartan Produkt AB
>>> mobile: +46 733 206831
>>> mailto: ao at t-kartor.sehttp://www.t-kartor.com
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> /tʃaɪθənjə/ /kʊmɑr/
>> +91-9494447584
>> 17.2416N 80.1426E
>> Andreas Oxenstierna
>> T-Kartan Produkt AB
> Best regards,
> Chaitanya kumar CH.
> /tʃaɪθənjə/ /kʊmɑr/
> +91-9494447584
> 17.2416N 80.1426E
Ing. Daniele Romagnoli
GeoSolutions S.A.S.
Software Engineer
Via Poggio alle Viti 1187
55054 Massarosa (LU)
Italy
phone: +39 0584 962313
fax: +39 0584 962313
mob: +39 328 0559267
http://www.geo-solutions.it
http://geo-solutions.blogspot.com/
http://www.youtube.com/user/GeoSolutionsIT
http://it.linkedin.com/in/danieleromagnoli
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110413/9eecb68a/attachment-0001.html
