[gdal-dev] Gamma parameter not set in proj4 string for RSO
	projections
    Hilmy Hashim
    hilmyh at gmail.com
    Thu Apr 14 03:09:14 EDT 2011
Sorry to bring this up again. I've been looking for why epsg_tr.py -proj4 is
not including the +gamma (RectifiedToSkew angle) parameter for the
+proj=omerc projection as used in EPSG:3168, EPSG:3375, etc. It seems that
it is not set in
https://svn.osgeo.org/fdo/trunk/Thirdparty/gdal/ogr/ogr_srs_proj4.cpp:
else if( EQUAL(pszProj,"omerc") )
        SetHOM( OSR_GDV( papszNV, "lat_0", 0.0 ),
                OSR_GDV( papszNV, "lonc", 0.0 ),
                OSR_GDV( papszNV, "alpha", 0.0 ),
                0.0, /* ??? */
                OSR_GDV( papszNV, "k", 1.0 ),
                OSR_GDV( papszNV, "x_0", 0.0 ),
                OSR_GDV( papszNV, "y_0", 0.0 ) );
        else
            sprintf( szProj4+strlen(szProj4),
                     "+proj=omerc +lat_0=%.16g +lonc=%.16g +alpha=%.16g"
                     " +k=%.16g +x_0=%.16g +y_0=%.16g ",
                     GetNormProjParm(SRS_PP_LATITUDE_OF_ORIGIN,0.0),
                     GetNormProjParm(SRS_PP_CENTRAL_MERIDIAN,0.0),
                     GetNormProjParm(SRS_PP_AZIMUTH,0.0),
                     GetNormProjParm(SRS_PP_SCALE_FACTOR,1.0),
                     GetNormProjParm(SRS_PP_FALSE_EASTING,0.0),
                     GetNormProjParm(SRS_PP_FALSE_NORTHING,0.0) );
There seems to be some uncertainty about this parameter. How can this be
resolved and how can I help?
Thanks.
*Hilmy*
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110414/3cd27e22/attachment.html
